Bellhousing identification and shifter positions
Postby KinLoud » Tue May 01, 2007 12:14 am
Thought I would post up pics of some bellhousings to help people work out what they have got...
G bellhousing off a 1981 GX61 Chaser 1GEU motor.
S bellhousing - SX6x Mark II, Cressida etc. Also C bellhousing the same - CA60 Carina wagon, CM30? Liteace with G52 gearbox (same bolt pattern as W series gearbox).
Y bellhousing - YX70 Mark II wagon, YM30 Liteace with G52 gearbox (same bolt pattern as W series gearbox). Can be used on a S motor to put starter on other side of block if the top right hole is slotted See the hole in the top right is slightly lower than the S/C bellhousing.
R bellhousing - RX30? Cressida
M bellhousing - MA60, MA70 Supras
SHIFTER POSITIONS
Postby l1ttle_d3vil » Wed May 02, 2007 8:45 pm
anyone wana do me a favour and post up a front on pic of their 4a series bellhousing? preferably 4a - t50. and this should be faq'd! (if its not already, wasnt last time I looked)
Postby ps165 » Thu May 03, 2007 1:32 am
l1ttle_d3vil wrote:anyone wana do me a favour and post up a front on pic of their 4a series bellhousing? preferably 4a - t50. and this should be faq'd! (if its not already, wasnt last time I looked)
not ideal, but only one i got.
T50 4AGE - AE86, AA63 celica, carina, + others
W5x > 3TGTE - TA63 celica, gt corona, plus some others
R154 > 1JZ - soarer, supra, possibly others
R154 > M - supra
ps165
Postby Rick » Thu May 03, 2007 7:03 am
Heres is my 3A to T-50 bellhousing, same as a 4A-T-50 housing but with the clutch fork on the passengers side.
Postby l1ttle_d3vil » Sun May 20, 2007 9:50 pm
someone want to FAQ this? quite a handy reference to have...
Postby Mr Revhead » Sun May 20, 2007 10:43 pm
agreed.
anything else anyone wants to add?
Postby KinLoud » Sun May 20, 2007 11:06 pm
Warwick - I still have a couple more... plus better pics of some already posted.
If you FArQ this we can still post to add more?
I'm working on more shifter positions... also
Ken
Ham
021 408 863
Postby Mr Revhead » Sun May 20, 2007 11:21 pm
no, only admin and mods can post in the FAQ section
so iv done this:
http://forums.toyspeed.org.nz/viewtopic.php?p=574282#574282
when/if this thread is finished it can be moved
Postby l1ttle_d3vil » Tue May 22, 2007 11:54 pm
can someone please do me a massive favour...
if you have a 2c / 3s bellhousing sitting around, can you measure up between these points for me please?? to the centre of the bolt holes. also need the distant between the starter motor bolts too.
hope it makes sense. :lol:
thanks.
Postby AE25 » Mon Mar 22, 2010 7:06 pm
edit: originally asked what from to help someone.. but research suggests L series diesel (2L, 3L, 2L-T, 3L-T) bell housing, but yet to find 100% definate confirmation pic.
E2 & E7 fanatic
http://www.toycrazy.net
AE25
Postby matt dunn » Mon Mar 22, 2010 11:34 pm
Interesting thing if found the other day,
all the w series bellhousings are labelled on the surface that mounts to the gearbox, so if you remove the housing there is a letter in there.
I now know the mystery bellhousing I have is an L series diesil one.
