heat treating of suspension parts
Postby Mr Revhead » Tue May 08, 2007 11:14 pm
ok, so i need to modify some suspension arms....
ke70 ones to be exact, so "U" section pressed steel
basicly i will be tigging in some extensions.
now its been a loooong time since highschool where we touched on heat treating etc of metals....
tigging the arms will heat some sections quite a bit, iv been told that after welding the entire arm should be heated then left to cool very slowly to "normalize" it and relieve stress points.
can any one clarify that?
ie is it bollocks? if not, do i heat it cherry red? etc.
please note: cert guy has been consulted etc so i know what im in for in order to get the arms certed etc so no "you cant heat suspension parts" post please :D
Postby Volodkovich » Tue May 08, 2007 11:59 pm
From what ive read yes heat treat them if you are going to do it properly - i.e. send them somewhere where they can put them in an autoclave and slowly heat the part up to required temp and slowly cool it.
Home heat treating is a no-no as you cannot be certain how hot you are getting the part and the cooling rate cannot be controlled properly.
Volodkovich
Re: heat treating of suspension parts
Postby rwd_mayhem » Wed May 09, 2007 10:47 am
Mr Revhead wrote:tigging the arms will heat some sections quite a bit, iv been told that after welding the entire arm should be heated then left to cool very slowly to "normalize" it and relieve stress points.
thats right to normalise it you need to heat it past the A3 temperature, which should be around 720 degrees, hold it at that temperature for a certain amount of time then slowly cool it. im studying mechanical engineering and we just did this sort of stuff.
current: 1975 Valiant Regel
previous: 1980 mazda 626, 4AGE AE70 sedan, AE70 sedan, mk2 escort, KP60 starlet, TE71 liftback X2
rwd_mayhem
Postby Mr Revhead » Wed May 09, 2007 10:49 am
hmm how hot can i get our oven? :lol:
so its send them off to get it done.....
Postby TRD Man » Wed May 09, 2007 11:16 am
Warwick, the practice of adding about an inch into these arms was common place amongst the rally fraternity back in the 70's & 80's when we all ran rwds.
Back then we didn't tig/mig them. Most if us just had the gas welding gear.
We'd weld in our extensions together with a suitable brace, get about 2/3's of the arm glowing red and chuck it outside to cool down at air temperature.
Never had a single failure and never heard of any others either.
Of course we didn't have to worry about engineers reports back then.
TRD Man
Postby Mr Revhead » Wed May 09, 2007 11:25 am
thats pretty much the method i was given, with the exception of to cool in a draught free room to slow the cooling process as much as possible.
with my wonderful tigging, some areas may receive some excess heat! :lol:
Postby big_boy » Wed May 09, 2007 2:13 pm
just heat treet them like burt munro douse things dip them in the drinking water
or for a better approch do you know any one with a kiln (think thats what there called big oven for clay) thats what i used on my FX-GT arms left them in that for about 8hrs then just turned it off & left the door shut about 2 days later i picked them up & they were still about 30`c or so warmer than i wanted to hang on to any way
for sale EE90
big_boy
Postby fangsport » Wed May 09, 2007 5:32 pm
Warwrick, why are you needing to extend the arms, and how much longer do you want them?
there are plenty of options to get the negative camber you are aiming for, maybe?
fangsport
Postby Volodkovich » Wed May 09, 2007 5:34 pm
Don't early model sigma LCA's fit ke70's and add a couple degrees camber?
Volodkovich
Postby Mr Revhead » Wed May 09, 2007 5:43 pm
am fitting aa63 front struts
those struts give positive camber with the stock ke70 lower arm
id be keen on more specific info on those mitsi arms.....
Postby fangsport » Wed May 09, 2007 5:45 pm
Mr Revhead wrote:am fitting aa63 front struts
why not use the AA63 arms as well?? they are a sh!tload longer than KE70
fangsport
Postby Mr Revhead » Wed May 09, 2007 5:54 pm
because i dont have them
i also need some form of camber adjustment, so id have to cut them up as well.
Postby fangsport » Wed May 09, 2007 6:33 pm
Mr Revhead wrote:because i dont have them
camber plates?
fangsport
Postby Mr Revhead » Wed May 09, 2007 9:23 pm
no thanks.... this is waaaaaaay cheaper, and i get to do it myself 8)
plus i doubt youd get enough adjustment from them
Postby Logan » Wed May 09, 2007 9:54 pm
the parts are more than likely your average joe mild steel. Welding will increase the parts suceptability to fatigue, however do it properly so the true load is transfered around the weld, by braces/overlapping in right places and you will never ever get near the endurance limit.
And... if you are going to that sort of effort, and must be certified, just put a rod end in there!
Also, more important than heat treated would be getting the parts crack tested.....
SR Sold. Onto Other Things
Logan
Postby fangsport » Wed May 09, 2007 9:55 pm
are you building a 'bozu' style KE70 with 10 degrees of neg? :lol:
fangsport
Postby Mr Revhead » Wed May 09, 2007 9:56 pm
just wait till u see the camber on the rear!! :lol:
Postby fangsport » Wed May 09, 2007 10:09 pm
Mr Revhead wrote:just wait till u see the camber on the rear!! :lol:
can i expect ' how much can you bend an axle tube before the axles fully bind?' as your next offering?
fangsport
Postby Dell'Orto » Thu May 10, 2007 12:24 am
No no, you just cut the axle and weld in a UJ, works a charm :lol:
Postby frost » Thu May 10, 2007 12:26 am
did you get those struts from christchurch? on TM, if so :evil: i was wanting those and asked for the buynow but someone clicked b4 i did.
