is this the correct setup for a catch can or am i going to lunch my motor?
there is alo a bigger hose on the other side of the motor (air box side) which must be around 17-19mm ID? this pumps out way more air from the head and feeds it into the air box (compared to the small line)
i am planning on plumbing this into a catch can also, but have to figure out how to get a big hose working with it.
i assume both of these are ok to go into the same catch can and should be vented to atmosphere via a mini breather filter?
the hose with the bolt into it in the pic above goes into the intake plenum, and now is obviously blocked off
any comments?
