Calling all AE111 owners....
Postby Crampy » Mon Jul 14, 2008 3:08 pm
Just want to confirm some things about AE111 gearboxes.
Can owners please state what car they own, eg: Levin, Trueno, BZ-G, BZ-V or BZ-R etc...
Then the gearbox code as stated on the VIN plate, eg: C56-**A, C56-**C or C160.... etc.
Also, whether or not it has superstrut suspension.
Cheers.
Crampy
Postby xsspeed » Mon Jul 14, 2008 5:56 pm
1996 Trueno BZG
C56-04a
Non Super-strut
Worthwhile asking if they are superstrut or not to confirm if they in fact did come with lsd
Postby Crampy » Mon Jul 14, 2008 6:03 pm
xsspeed wrote:1996 Trueno BZG
C56-04a
Non Super-strut
Ahhhh yes, good point.
That was the whole point of me starting this thread.
EDITED.
Cheers.
Crampy
Postby astrae » Mon Jul 14, 2008 6:16 pm
1996 Levin BZG
C56-04a
Non Super-strut
astrae
Postby TRD_ZERO » Mon Jul 14, 2008 7:38 pm
1996 Levin BZG
C56-**C
Super Strut
TRD_ZERO
Postby Crampy » Mon Jul 14, 2008 7:41 pm
TRD_ZERO wrote:1996 Levin BZG
C56-**C
Super Strut
Now this is what I'm wanting to know. Are you able to confirm whether the car has an LSD or not?
Crampy
Postby TRD_ZERO » Mon Jul 14, 2008 9:03 pm
well when i jack the front up and turn 1 wheel the other doesnt turn. But that doesnt mean it isnt lsd as ive been told, it all depends on what lsd it is. So what kind of lsd are they supposd to have? viscous, heclical, plate?....im guessing it isnt plate.
TRD_ZERO
Postby Bling » Mon Jul 14, 2008 10:54 pm
park a wheel on grass, the other on the road and try take off fast. easy way to tell. LSD to take off, non-LSD you spin the wheel on grass
Postby bs » Mon Jul 14, 2008 10:56 pm
Trueno - pritty sure its a bzg. ( chassie# BCMZF )
C56 04C - Pritty sure it is lsd to :lol:
And it is superstrut...But not for long.
Wikipedia:
C56
A 5-Speed Manual Transmission for FWD cars.
Gear ratios for this transmission.
1st 2nd 3rd 4th 5th Reverse Final
3.166 1.904 1.392 1.031 0.815 3.250 4.312
C160
A 6-Speed Manual Transmission for FWD cars including a optional limited slip differential.
1st 2nd 3rd 4th 5th 6th Reverse Final
3.166 2.050 1.481 1.166 0.916 0.815 3.250 4.529
Maybe that helps a little bit?
bs
Postby TRD_ZERO » Mon Jul 14, 2008 11:48 pm
BS if you jack your car up then turn one wheel what happens to the other wheel?
TRD_ZERO
Postby Crampy » Tue Jul 15, 2008 12:23 am
TRD_ZERO wrote:BS if you jack your car up then turn one wheel what happens to the other wheel?
Now, the problem with that is the type of diff they have will not always act as a normal LSD. They aren't plate diffs, they're torsen or viscous or something. Apparently they need a certina amount of load on them before they apply drive to the other wheel. I might do a search to find out more on them.
So, far it's looking like the superstrut's are onto a winner with the LSD. Anyone else with a AE111?
Crampy
Postby Crampy » Tue Jul 15, 2008 12:27 am
Any BZ Touring wagons? What's the gearbox code on them, compared to a BZ-R Levin?
Crampy
Postby jetshin » Tue Jul 15, 2008 2:22 am
BZ-V here, has LSD box and superstrut
jetshin
Postby AceSniper » Tue Jul 15, 2008 3:22 am
there gear driven lsd's so yea the turn one wheel dont work.
AceSniper
Postby 1I1 » Tue Jul 15, 2008 9:31 am
AE111 Sedan
C160
Open diff
Non-superstrut
TRD Clicky >>Here
1I1
Postby Boosted_162 » Tue Jul 15, 2008 7:42 pm
BZG|Bling wrote:park a wheel on grass, the other on the road and try take off fast. easy way to tell. LSD to take off, non-LSD you spin the wheel on grass
Doesnt that only work with certain LSDs? Im pretty sure my SW20 wont do that with one on both surfaces, but it will always spin both on tarmac. And it definately came with an LSD standard.
Postby NILPSI » Tue Jul 15, 2008 11:13 pm
Mines Non-superstrut BZ-G
Factory had NO LSD
I have since put a superstrut gearbox in it which IS LSD, easiest way i found to tell is drive at 50km/h in 4th, if it sits just on or slightly over 2000rpm its LSD, if it sits well over more like 2200 - 2300 rpm its Non-LSD, the LSD boxes have a different final drive. Thats was the giveaway when i put the new box in my car, well besides the 2 black lines i left on the workshop floor :P
Long story short ALL non superstrut ones I personally have seen have been non LSD, all superstrut ones i have seen have had LSD and the bigger twin-pot brakes
Also the whole one wheel on grass thing, from what i understand these are viscous LSDs from the factory, they work as a normal LSD when both wheels are on the same surface, when they are not they work as an open diff (eg. Grass and Tarmac or Tarmac and Gravel)
I hope this helps?
If anybody knows any different please let me know, ide hate to be giving out incorrect info
17 Triton - The "free supplied by work" daily
09 Aurion Sportivo - The Daily
97 Trueno BZ-G - The Garage Queen
97 Supra SZ-R - The never ending project... now with added boost!!
NILPSI
Postby Crampy » Wed Jul 16, 2008 9:04 am
So, would I be correct in assuming that out of all the C160 (6 speed) cars, the BZ-R levin is the only one with LSD as standard? My mate is picking up a 6 spped BZ Touring wagon tomorrow (well we are. Road trip!!!)
I'll check the number on it to confirm if LSD or not.
Crampy
Postby 1I1 » Wed Jul 16, 2008 9:40 am
NILPSI wrote:Mines Non-superstrut BZ-G
Factory had NO LSD
I hope this helps?
That'll be a 5speed box too, the 6speed ones are doing close to 3000rpm in 4th at 50
TRD Clicky >>Here
1I1
Postby Crampy » Wed Jul 16, 2008 10:39 am
Factory had NO LSD
I hope this helps?
Are they?
Geez man, it seems you'd be changing gear more than actually driving, with a 6 speed :lol:
Crampy
