frost wrote:the problem i see is you wont spin the turbo to a speed where you'd make good psi. where as the procharger and the uk made charger of the same configuration have a gearbox arrangement to get the turbo up to speed. if its just direct drive from pulley to pulley, you'd have to have quite a big ratio to spin it to get most turbo's to optimum islands. 100,000 rpm's for most low inertia turbos and up to 200,000 for very high end turbo's. something silly like dinner plate to tea cup sized pulley's
whats your thoughts about this? and how will you over come this.
