Caldina GTT engine light code
Postby sleepy » Fri Jan 08, 2010 10:51 am
Hi there, I recently started getting the engine check light on my gtt. I read through some threads here and found out how to read the codes by jumpering the TC and CG on the connector. I am getting 15 error code from the diagnostic connector.
Does anyone know what code 15 means?
sleepy
Postby MR2BOY23 » Fri Jan 08, 2010 10:55 am
You sure its 15 not 14?
MR2BOY23
Postby MR2BOY23 » Fri Jan 08, 2010 10:56 am
If it is in fact 14 its the following
- igniter and ignition coil circuit
- ECU
no igf signal to ecu
MR2BOY23
Postby sleepy » Fri Jan 08, 2010 10:56 am
Pretty sure it is 15, will go check it again.
sleepy
Postby FLAWLES » Fri Jan 08, 2010 10:58 am
MR2BOY23 wrote:You sure its 15 not 14?
gah bet me to it
FLAWLES
FLAWLES
Postby MR2BOY23 » Fri Jan 08, 2010 11:00 am
Sorry st215 caldina
MR2BOY23
Postby sleepy » Fri Jan 08, 2010 11:03 am
I just checked it again, and this is what I see. 1 flash followed by a 1 second break and then 5 flashes. Is it 15 or 51?
sleepy
Postby fivebob » Fri Jan 08, 2010 11:16 am
Code 15 means it's likely that one of you coils is failing (Cylinder #2 or #3), or at least failing to return a signal back to the ECU.
Postby fivebob » Fri Jan 08, 2010 11:23 am
To determine which cylinder it is swap the coils on #1 & #2, clear the codes and wait for the Check Engine Light to come on again, then check the codes again.
If it's still code 15 then it #3 coil, if it changes to 14 then it's the coil that is now on #1 :wink:
Postby sleepy » Fri Jan 08, 2010 11:25 am
Hi fivebob, I see you are the guru on the 3sgte's (according to the threads I have been reading hahah)
This may sound silly, if i replace the ignition coil will the problem go away if it is the coil and not on the ecu end? also where is the coil in the car and is it a easy job to do?
Can it also be related to spark plugs/leads failing? or is it just strictly the ignition coil?
EDIT: the swapping of the coils you talking about, do you mean swap the spark plug leads?
Avi
sleepy
Postby fivebob » Fri Jan 08, 2010 11:41 am
sleepy wrote:This may sound silly, if i replace the ignition coil will the problem go away if it is the coil and not on the ecu end? also where is the coil in the car and is it a easy job to do?
The problem will go away if it's the coil ;)
The coils are on the top of the sparkplugs.
It's possible for it to be a plug, though very unlikely as that should show up as a code 93. There are no leads as such it's a "coil on plug" system, but it might be the connector or wiring, though again that's very unlikely.
There are no leads, you have to swap the coils.
If you swap #1 & #2 coils, and you still have a #15 fault, then to be sure it's #3 coil then swap that with #4 and try again.
If it's still a code 15 then try swapping the sparkplugs on #2 & #3 with #1 & #4 to see if it changes to a code 14. If it is still a code 15 it's either your wiring or the ECU :cry:
Postby sleepy » Fri Jan 08, 2010 11:53 am
Brilliant that clears everything up. Just before I start fiddling with this:
1) Attached is the image you are referreing to correct? Just unplug them at the sparkplug end and swap them around?
2) Reset the ecu and see if the engine light comes on and check the error codes etc?
Also the cylinder numbers are from left to right 1 to 4? or is it 1, 3, 2, 4?
sleepy
Postby fivebob » Fri Jan 08, 2010 11:59 am
Disconnect the connectors (one cylinder will be a brown connector the other will be grey), remove the bolt from the top of the coil that attaches it to the cam cover pull out the coil units and swap them over, bolt them up and reconnect them.
You may have to remove the intercooler to get at the coils.
Cylinders are numbered from the front of the engine to the back. i.e. cylinder #1 is nearest the crankshaft pulley #4 is nearest the gearbox.
Postby sleepy » Fri Jan 08, 2010 12:05 pm
Awesome, thank you for that :).
sleepy
Postby sleepy » Sat Jan 09, 2010 5:55 pm
Looks like my problem is solved. Took the intercooler off and was disconecting the connectors to the coils but they came off very easily as all of them werent properly plugged in all the way till they clicked. So when I booted the car, the engine movement might have pulled on to the connectors a little bit. Blame my mecahnic for that -_- Plugged all of them back in, resetted the efi and went for a drive, no engine light :).
Thanks a lot for the help guys :D.
sleepy
