Dyno day @ Spec - Saturday 4th September
Postby BWDOWN » Sun Aug 08, 2010 9:36 pm
Well after such a good day on saturday we are doing it again.. I had about 5 people with all sorts of cars asking me to hold another. So seeing as my car is still not finished I will be making it to this next one hahaha
Hopefully we can have another good turnout. 2WD and 4WD whatever you like. I'll be advertising this on other forums this time too
Where: Spec Performance - 417 St Asaph Street
When: Saturday 4th September
Price: $50 per car (Normally $80)
If your interested please post below :)
B20vtec Allmotor 90% of the way to 170wkw Thanks to 0800 cartune 41.co.nz & Spec Performance
My Profile
BWDOWN
Postby matt dunn » Sun Aug 08, 2010 9:52 pm
Spec tune a few of my mates car that I race against,
so would be good to compare tham on the same dyno.
As long as I dont end up wrking for a race team at the Ruapuna Enduro the same day I will probably be there.
Postby BWDOWN » Wed Aug 11, 2010 2:02 pm
Only 1 spot left
If you want it Matt, let me know asap
Otherwsie will end up doing one in a couple of months
My Profile
BWDOWN
Postby matt dunn » Fri Aug 20, 2010 2:08 am
I won't be there,
I will be a Ruapuna instead.
Matt
Postby 4bid1n 2jz » Fri Aug 27, 2010 7:00 pm
ill full in the spot if its still there be good to see what the new aristo is putting out before i do anything to it
jzs161 aristo 2jzgte vvti
projects
townace van 3tgte
ke35 sr coupe
and a turbo starion
4bid1n 2jz
Postby BWDOWN » Sun Aug 29, 2010 1:28 am
4bid1n 2jz wrote:ill full in the spot if its still there be good to see what the new aristo is putting out before i do anything to it
Yep done mate, anytime on the day you would prefer to run seeing as I guess your coming up from ashvegas?
Whats your 1st name?
Thanks
My Profile
BWDOWN
Postby 4bid1n 2jz » Sun Aug 29, 2010 5:54 pm
tony and after 12 would be good
projects
townace van 3tgte
ke35 sr coupe
and a turbo starion
4bid1n 2jz
Postby BWDOWN » Sun Aug 29, 2010 10:06 pm
4bid1n 2jz wrote:tony and after 12 would be good
Done & Done
Is it a 2JZ Aristo?
My Profile
BWDOWN
Postby 4bid1n 2jz » Sun Aug 29, 2010 10:15 pm
yep sure is vvti turbo 2jz
projects
townace van 3tgte
ke35 sr coupe
and a turbo starion
4bid1n 2jz
Postby BWDOWN » Sun Aug 29, 2010 10:30 pm
Excellent man
Dyno day now presented in association with Performance Industry and Spec Performance
www.performanceindustry.co.nz
www.specperformance.co.nz
T shirts will be on offer for Highest NA Dyno and Highest Turbo Dyno Power
Maybe some other spot prizes on the day as well
List Below:
Entrant List:
1. BWDOWN - EK9
2. Karl - Mivec Lancer
3. XPLOIT - Accord
4. Graphite - Turbo CRX
5. Illcit - Integra
6. XDUP13 - S13 Silvia
7. Cherie - S14 Silvia
8. Lachlan - RS Four S Stagea
9. Daniel - Toyota Supra
10. Richard - Mitsi Mirage Turbo
11. SXCS14 - S14 Silvia
12. Hugo - Ford Falcon XR8
13. BLK180SX - Nissan 180SX
14. Tony - Toyota Aristo
15.
16.
My Profile
BWDOWN
Return to Christchurch / Upper South Island Region
