Silver top ecu to black top ecu
Postby FLESHAXXE » Sat Oct 16, 2010 12:33 pm
Does anyone have the wiring dia ...silvertop (manual) to blacktop (automatic ecu)
FLESHAXXE
Postby dusk93 » Sat Oct 16, 2010 3:26 pm
http://i229.photobucket.com/albums/ee18/4age20v/ECU_AE101_20V_4A-GE-Manual_01.jpg Silvertop manual ecu pinouts,
http://www.club4ag.com/faq_and_tech_pages/Tech%20Photos/ECU_AE111_20V_4A-GE.jpg Blacktop ecu pinouts
Hope that helps, you can get a whole blacktop service manual pdf off the net too if you get stuck.
Current: 1983 AA60 Coupe, 1987 E30 318i coupe, 1985 SA70 Parts Heap, 1990 R32 GTST Coupe
Ex: 1982 AA60 Coupe, 1987 AE92 FXGT (RIP), 1989 Mazda Astina BG hatch, 1994 R33 Skyline GT ( RB20E powered :( )
dusk93
Postby soopachargen » Sat Oct 16, 2010 7:12 pm
when i did my blacktop conversion i found there seemed to be a lot of redundant wires in the the silvertop loom, one of the computers... i think its the silvertop also has wiring codes on the circuit board where the pins connect, so if you take the cover off you can reference those
When in doubt, down and out.
soopachargen
Postby ChaosAD » Sun Oct 17, 2010 10:58 am
If you have an auto silvertop loom, the pinout is almost identical to the blacktop ecu.
There is a silvertop wiring diagram available in the tech section of club4ag.com
ChaosAD
Postby FLESHAXXE » Thu Oct 21, 2010 7:30 am
THANK you very much guys you have been a great help....THANKS dusk93 for those diagrams they have been a great help...cheers..
FLESHAXXE
Postby gmacrae » Thu Oct 21, 2010 9:12 pm
my silvertop runs a blacktop ecu - goes heaps better too, little bit flat below 2000 rpm but better overall.
gmacrae
Postby whynot » Thu Oct 21, 2010 9:20 pm
I got an ecu done by chaosAD and tuned it my self. goes fine but no idea how much better than standard. hopefully on the dyno this weekend at mega meet.
whynot
Postby FLESHAXXE » Thu Nov 25, 2010 12:34 am
I have decided to replace the entire silvertop (manual) harness with the blacktop (manual )harness. There were a few connections in the engine bay that had to be changed other than that there is a pair of plug in harness that come through the firewall with the set that plugs into the computer. The problem is these are different from what is there in the car .That extra pair on both harness are different.Does anyone have the diagrams for both or can point me in the right direction?
FLESHAXXE
Postby FLESHAXXE » Tue Dec 07, 2010 5:42 am
I got everything completed guys....the car is up and running...
FLESHAXXE
Postby Dragger_Dan » Tue Dec 07, 2010 4:53 pm
gmacrae wrote:my silvertop runs a blacktop ecu - goes heaps better too, little bit flat below 2000 rpm but better overall.
Where have you connected your MAP sensor to the silvertop intake? I'm not sure I've got mine right as it seems to run a bit rich, leaves a bit of a cloud behind it over 6000rpm.
Dragger_Dan
Postby gmacrae » Tue Dec 07, 2010 7:06 pm
yea i call it the great cloud of awesome :D
but na, i just took a vac feed off the chamber above the throttles that goes to all four. It does run a bit rich, which i dont get because i thought the ecu should be using the o2 sensor during cruise
gmacrae
Postby FLESHAXXE » Thu Dec 09, 2010 3:33 am
I have tapped into the line that goes to the fuel pressure regulator...I find the car to be running a bit rich as well......
FLESHAXXE
Postby sergei » Thu Dec 09, 2010 8:00 am
FLESHAXXE wrote:I have tapped into the line that goes to the fuel pressure regulator...I find the car to be running a bit rich as well......
wrong line. You will need to tap into the little manifold above throttles.
Postby FLESHAXXE » Fri Dec 10, 2010 3:09 am
Thanks Sergei....will do...
FLESHAXXE
Postby FLESHAXXE » Fri Dec 10, 2010 3:38 am
Sergei excuse my ignorance but I'm not seeing where you mean ....will try to send diagram..[/quote]
FLESHAXXE
Postby gmacrae » Fri Dec 10, 2010 8:01 am
if its a stock silvertop, you want to tap into the aluminium chamber on top of the throttles. It's the one that the head/pcv vents into, at the rear end of the chamber there's a round frost plug lookin thing and a few vac sources off that end. Its half hidden under the plastic cover for the injector wiring. That chamber takes a vac feed from all 4
gmacrae
Postby FLESHAXXE » Fri Dec 10, 2010 8:59 am
Can I use the vac off that end by the frost looking plug...
FLESHAXXE
Postby gmacrae » Fri Dec 10, 2010 9:11 am
yep any one of those nipples will do the trick, you're just after a nice smooth (equalised) vacuum signal, not like the one you've got. The top chamber is perfect. Like i said though, mine still runs a bit rich - possibly more to do with my 02 sensor tho
gmacrae
Postby FLESHAXXE » Wed Dec 29, 2010 6:59 am
Well guys I have a new problem.....when I try to accelerate the car suddlenly it bogs down for lack of a better term...however when I unplug the TPS the car revs and drives very good except for a little high idle(1500rpm)....I have changed the TPS but I have to get it set...I think it is 1.8ohms -18.5ohms at full throtle...this is driving me crazy...
FLESHAXXE
Postby FLESHAXXE » Sat May 21, 2011 6:16 am
THANKS GUYS for the help that you have given me...I took the car to an electrician and there were a few bad connections .Everything is running smooth now....CHEERS ...
FLESHAXXE
Users browsing this forum: Bing [Bot], Google [Bot] and 10 guests
