TRD LSD oils? what do you use
Postby ke25sr » Fri Feb 11, 2011 12:55 pm
i have been using a synthetic 75W 140 LS gear oil in AE86 2 way.
Wondering what others have been using?
ke25sr
Postby Bazda » Fri Feb 11, 2011 1:43 pm
Motul gear competition
Castrol SAFXA is meant to be the one to use these days, and its real cheap to buy from a Ford dealer.
Postby ke25sr » Fri Feb 11, 2011 1:56 pm
Also found Penrite hypoid 85W-140 to be in specs too.
ke25sr
Postby Dell'Orto » Sat Feb 12, 2011 6:00 pm
Geartech recommended me 80w140 Redline for mine
Postby 4agtepwr » Sun Feb 13, 2011 1:42 pm
Motul comp gear oil, its expensive but so is rebuilding gearboxes
Current ride: Sweeeeet Hiace. 3L power!!!!
Project: AW11 4agte, 410kw 555hp on 26psi
11.1 @ 125.5mph with more to come, As seen in Aug 2011 Performance Car, haha
viewtopic.php?t=61383
Huge thanks to Phil from NZEFI, Al and Brendan from Caraid and Hamish from Sheifield Cresent Auto
4agtepwr
Postby 71TA22 » Sun Feb 13, 2011 5:30 pm
Castrol LSX 90 and past Castrol equivalents.
280,000 km on a RWD factory 2 way LSD.
Mike
71 TA22
My Car
71TA22
Postby ke25sr » Sun Feb 13, 2011 5:51 pm
RD require a multi grade, the LS 90 type oils are not right unless you running a stock LSD
71TA22 wrote:Castrol LSX 90 and past Castrol equivalents.
ke25sr
Postby 71TA22 » Sun Feb 13, 2011 10:10 pm
ke25sr wrote:RD require a multi grade, the LS 90 type oils are not right unless you running a stock LSD
I'm interested to know what the difference between a T293 factory LSD and an early TRD T series LSD is?
Toyota mechanics considered opinion was to use the multigrade oil for racing (more bite) and the 90 on the street (smoother).
Mike
71 TA22
My Car
71TA22
Postby ke25sr » Mon Feb 14, 2011 11:18 am
Info from TRD Website, the FF type TRD LSD still is recommended to use a LS90
TRD LSD oil FR is a multi-grade gear oil developed for differentials in vehicles equipped with an LSD. This 85W-140 grade oil maintains its viscosity index across a wide range, and exhibits superior oil film characteristics under both heavy loads and high temperatures, thanks to its special pressure and wear agents, which help to soften shocks and maintain gear teeth. What's more, its special friction-regulating agent maintains the ultra-high LDS performance that is demanded by motor sports and other extreme driving activities.
ke25sr
