Toyota Wilwood BIG Brake Kits - AE86/82/92/101/111
Postby Bazda » Fri Jul 15, 2011 10:21 am
FortuneAuto|Wilwood|Quartermaster|Fidanza|ARP|TRE|MOTUL|MasterPower|RC Injectors|Aeromotive|STD Suspension|Enkei|Rota Wheels|Work Lug Nuts
Wilwood Brake kits (Calipers, Rotors, Adapter brackets, hardware etc)
- 4 piston, 6 piston, 2-piece rotors, brake bias valves
- Custom adapter brackets to fit calipers to any model car.
Massive gain in stopping power!, never have to worry about brake fade again. Pad replacement is fairly cheap!! starting from $115 for fast street up to $170 for race pads. Direct bolt up, no need to change master cylinders or Bias valves.
Corolla AE86 280mm Kit 15"+ Wheels - $1350 incl
Dynapro 4 piston caliper, 2-piece adapter brackets and hardware, 280x25mm discs (nice and thick!).
Add on parts: Braided lines $+115, 2-piece disc setup with aluminium hat +$230
Corolla 280mm (AE82/92/101/111) 15"+ Wheels - $1330incl
Suit Macpherson strut, Dynapro 4 piston caliper, Adapter brackets and hardware, 280x25mm discs (nice and thick!). This is our most popular kit PM us for more details!
Corolla 300mm+ (AE82/92/101/111) 16"+ wheels - $1500incl
McPherson Strut & Superstrut 300-315mm (Toyota Celica GT4 OEM Heavy Duty Discs) Superlite 4 Piston full bolt on kit with braided brake lines
RRP $1650
Celica ST202 300mm+ - $1500incl
McPherson Strut 300-315mm (Toyota Celica GT4 OEM Heavy Duty Discs) Superlite 4 Piston full bolt on kit with braided brake lines
RRP $1670
We can also do brand new Toyota OEM ST205 GT4 4 pots onto any of the above setups!! it does add a little extra cost around $200-300.
Also we can custom fit these Wilwood brake calipers onto anything! just ask!
AE86, Supras, Escort, Honda, Primera etc
Postby Bazda » Tue Jul 26, 2011 10:08 am
Bumping this up as these have been really popular recently!!.
So popular we ran out of stock and waiting on the next shipment from USA.
Postby solitaire » Tue Jul 26, 2011 9:12 pm
Stupid question but I'd need a cert after fitting wilwood brakes correct?
AE92, KZJ120, KDJ120
solitaire
Postby levinguy » Tue Jul 26, 2011 9:18 pm
solitaire wrote:Stupid question but I'd need a cert after fitting wilwood brakes correct?
yes.
wishful thinking at this stage, but, how much for a full bolt on clutch kit for a sw20 turbo?
levinguy
Postby Bazda » Tue Jul 26, 2011 10:43 pm
Yes you will need a cert unless you have a nice WOF place who will pass you ;)
yes.
Yep sw20 kits can do. $1850
Postby Bazda » Sun Sep 11, 2011 9:23 pm
Bump - Now added 1uzfe to W55 twinplate clutch kit!
Shortly we will be bringing out the single plate versions which would be super lite weight! great for the n/a guys.
Postby Bazda » Thu Sep 22, 2011 12:43 pm
280mm Dyanpro kits are super popular.
Mucking around with superstrut 2 piston brakes?
Over heating your brake system?
If yes then you need this kit :).
We can also custom fit ST205 4-piston calipers onto Corolla Hubs.
Postby Prymal » Sat Oct 01, 2011 7:03 pm
twin plate for a st205 baz ?
St205 NZ New Group A WRC Gt4- Accept no Imitations !
Prymal
Postby Bazda » Sat Oct 01, 2011 7:40 pm
Prymal wrote:twin plate for a st205 baz ?
Yep can do one for a ST205.
Pm me for price.
Postby Bazda » Sun Oct 02, 2011 7:37 pm
Bump, added Celica ST202 brake upgrade kit :)
Superlite kits dropped from $1600 to $1500!
Postby Bazda » Sat Apr 20, 2013 5:32 pm
Bumping this up, always back ordered on brake kits. Lead times are now around 2 weeks.
Postby Prymal » Thu Apr 25, 2013 3:16 am
with the wilwood caliper , do they use a piston that has a dust shield ? I believe this is an issue with certing them in Australia ( hence the same with AP racing )
( im over in oz now barry , hence why you havent seen me at repco i onehunga - ended up needing life saving surgery )
its a long term goal to have bigger stoppers on the car , if i find the limitations of the 205 caliper
Prymal
Postby Garreth27 » Thu Apr 25, 2013 3:35 am
anything for a ep82 gt starlet?
Current Rides:
91 Gt Starlet - Forged 5efte Drag Toy
88 EP71 Turbo S Starlet Track Toy
99 SEX10 Altezza - Daily Driver
Garreth27
Postby Bazda » Thu Apr 25, 2013 9:46 am
Prymal wrote:with the wilwood caliper , do they use a piston that has a dust shield ? I believe this is an issue with certing them in Australia ( hence the same with AP racing )
Yes they have versions with the dust boots over the pistons. Its extra cost but not too much more.
Postby Bazda » Thu Apr 25, 2013 9:47 am
Garreth27 wrote:anything for a ep82 gt starlet?
Yes done those before, same price as the corolla kits.
Return to Toyspeed Sponsors
Users browsing this forum: No registered users and 0 guests
