st205 celica stuck iscv -- sorted!
Postby gt4dude » Sat Jun 16, 2012 3:31 pm
My understanding is with the 3 wires, pin 2 is positive, pin 1&3 are ground, ground out the left side it closes, ground out the right side it opens.
I've attacked it with carby cleaner and tried powering the pins no success, so i pulled it completely apart and I cant even turn that knob by hand, that knob should be able to turn right?
so this means i will need to replace both parts?? do they both come together?
anyone got any suggestions that might save me buying this new??
セリカGT-FOUR ST205 中期型 (Chuuki)
200AWKW / 370NM
gt4dude
Postby gt4dude » Sat Jun 16, 2012 4:05 pm
update: after soaking in carby cleaner for a while, the knob and the door have loosened up a bit, still gritty in there. fingers crossed it will work when i put it back together
200AWKW / 370NM
gt4dude
Postby gt4dude » Sat Jun 16, 2012 4:58 pm
gt4dude wrote:update: after soaking in carby cleaner for a while, the knob and the door have loosened up a bit, still gritty in there. fingers crossed it will work when i put it back together
Ok, attached the electronic part to the alloy part, the door is now opening and closing as it should when the appropriate terminals are charged. however the door when closed is not creating a 100% seal (boost leak) so instead of plumbing this to the air filter i will plumb it to the intercooler
put gasket in freezer hopefully will shrink a little and stiffen up so it can fit back in its place as i dont see a spare in my 3sgte gasket set leftovers
gasket shrunk, used a little drop of ados to get it to sit in there.
ISCV in
200AWKW / 370NM
gt4dude
Postby gt4dude » Sat Jun 16, 2012 7:10 pm
It's been a long ass fkn day but we have idle!
200AWKW / 370NM
gt4dude
