AE series drive shafts
Postby SkunkWeRX » Fri Aug 17, 2018 9:03 pm
Had a look through the tech post but couldnt find any info
Does any one know if the AE series drive shafts are all interchangeable?
such as 4afe models with 4age models etc??
SkunkWeRX
Re: AE series drive shafts
Postby Dell'Orto » Mon Aug 27, 2018 1:25 pm
They fit, but FE ones lack the hanger bearing the GE models do.
Postby GDII » Mon Aug 27, 2018 5:13 pm
Dell'Orto wrote:They fit, but FE ones lack the hanger bearing the GE models do.
Uneven length vs even length?
1990 SW20 MR2
Previous 1990 EE90 Corolla
GDII
Postby Dell'Orto » Tue Aug 28, 2018 2:21 pm
The drivers one is always long, but FE dont use the bearing that the GE ones do. Assume to do with lack of horsepower :lol:
Postby GDII » Wed Aug 29, 2018 9:22 am
Probably. What I meant about equal length is the inner CV joint on the right side matches where the inner CV is on the left technically making the end half shaft the same length reducing differences in power transfer to the wheels. The SW20 NA has a long right side while the turbo has the carrier bearing setup. GE vs GTE in this case.
1990 SW20 MR2
GDII
Postby KinLoud » Sun Sep 16, 2018 8:22 am
I know that with the hanger bearing setup the auto vs manual gearbox/driveshaft combo can't be mixed and matched.
Have to manual driveshaft for manual box as the lengths are slightly different and the hanger bearing won't bolt to the block
Fatal: Not able to open ./cache/data_global.php
