Caldina GTT thump when coming off accelerator
Postby Technohedge » Tue Nov 06, 2018 7:51 am
if I come off the gas quite hard there's a dull thump sound. Suspecting engine mounts (not sure where the rear ones are located?
Anything else to check?
Technohedge
Re: Caldina GTT thump when coming off accelerator
Postby GDII » Tue Nov 06, 2018 8:19 am
The rear mount is connected to the gearbox.
http://jp-carparts.com/toyota/partlist. ... 1&fig=1107
However based on experience of knocking and lifting of the gas quite hard it could be a ball joint in the suspension.
1990 SW20 MR2
Previous 1990 EE90 Corolla
GDII
Postby Technohedge » Tue Nov 06, 2018 10:22 am
Ok cheers bud I will check them out
Technohedge
Postby Malcolm » Mon Dec 03, 2018 9:34 pm
Could be the rear diff mount, common on GT-Fours so probably also an issue on the GTT
Fatal: Not able to open ./cache/data_global.php
