anyone with a 14mm helicoil kit?
Postby levinguy » Thu Oct 29, 2009 1:06 pm
that would let me borrow it? 1.5mm pitch
compensation in the form of beers will be provided
can't justify the cost of a whole kit that i'll only use once
levinguy
Postby Akane » Fri Oct 30, 2009 12:23 am
Actually I think I do
12.8mm drill bit, the hand turning thingee for cutting thread for a 14mm bolt, but don't know what thread pitch tho :(
Postby Burning Angel » Fri Oct 30, 2009 7:05 am
i assume this is for spark-plugs? if so powerbuilt sell a kit just for that, it comes with a tap and several different length inserts for different types of thread lengths. U can get them at repco/appco, i dont think they're very expensive
1984 SRP61 Starlet
1999 WRX Type RA
Burning Angel
Postby levinguy » Fri Oct 30, 2009 9:29 am
Burning Angel wrote:i assume this is for spark-plugs? if so powerbuilt sell a kit just for that, it comes with a tap and several different length inserts for different types of thread lengths. U can get them at repco/appco, i dont think they're very expensive
nope for a cage nut, that one of the suspension arms bolts onto :evil:
levinguy
Postby levinguy » Fri Oct 30, 2009 9:35 am
Akane wrote:Actually I think I do
care to measure it when you can? would be awesome if you could :)
levinguy
Postby Akane » Fri Oct 30, 2009 3:38 pm
Sure thing hold on
Edit: Guess what, looks like you're in luck. I have:
12.8mm drill bit
14mm x 1.5 Tap
Hand tapping tool
2 x Recoil "Timesert", inside: 12mm x 1.25, outside: 14mm x 1.5
Leftovers when I was doing a recoil on my 3S-GTE head.
Postby levinguy » Fri Oct 30, 2009 3:52 pm
Sure thing hold on
12.8mm drill bit
14mm x 1.5 Tap
Hand tapping tool
cheers for that
hmm stupid question, but wouldn't i be wanting the inside to be 14mm x 1.5mm as thats the size of the bolt?
levinguy
Postby Akane » Fri Oct 30, 2009 4:14 pm
Well, you can always thread it without the helicoil, just back to bare metal.
IE: You have a 12mm bolt, you stripped the thread, so what you do is just drill the hole out to clean out the threads, and retap it with a 14mm x 1.5 tap, and just put a 14mm x 1.5 bolt back in.
In my case, my aluminium cylinder head's exhaust manifold stud was stripped, it was a 12mm x 1.25 stud that was holding it all together.
So I drilled out the existing 12mm hole, retap it to 14 x 1.5, put a helicoil in, the helicoil's outer sleeve thread is 14 x 1.5m the inner sleeve's thread is 12 x 1.25. Reuse existing 12 x 1.25 stud and put everything back together.
Return to Auckland / Upper North Island Region
Users browsing this forum: No registered users and 22 guests
