Metal Engineer Recommendation: Remove, Tap, Straighten
Postby MrOizo » Sun Feb 26, 2012 10:38 pm
Hey guys.
Should have posted earlier but needing some one to do a pretty simple job for me - had a little boo-boo at work and $&#$% some things up!
Looking at the pic below, it can be seen that there is a bend on the left arm and in the end of this arm there is a sheared M5-6 bolt.
What i need to do is remove the bolt, straighten arm and i guess check for cracks around the welds or even have it rewelded.
Who would be the best to take this to at short notice?
Cheers.
MrOizo
Toyspeed Legend
Postby THA SHZ » Mon Feb 27, 2012 2:12 pm
Adrian try Rod at Brugar Engineering here in Barrys Point rd , tell him you're a friend of mine and he will sort ya out 8)
THA SHZ
Postby MrOizo » Mon Feb 27, 2012 2:28 pm
THA SHZ wrote:Adrian try Rod at Brugar Engineering here in Barrys Point rd , tell him you're a friend of mine and he will sort ya out 8)
Oh bugger! Took it to a place in Onehunga today.
If this doesnt work out, i'll go see the guy.
Cheers!
MrOizo
Toyspeed Legend
Return to Auckland / Upper North Island Region
