Help a Mitsi Man.....
Postby Dell'Orto » Tue May 01, 2007 7:57 pm
TazzieDevil wrote:Neo - Apparently, Kirks reckon a piston has collapsed... They mentioned they could take it all apart and give it a good look, but would be about 5 hours labour. But at their prices, would be $500. SO by the time they look at it, try and fix it and then reassemble, it would be at least $1500+ anyway.
Do they not have a borescope? I can do you a good deal on one ;)
Postby TazzieDevil » Tue May 01, 2007 9:01 pm
can i try before i buy? hehehe
Get In, Sit Down, Shut Up & Hold On
TS Profile
It wasn't Me, it was the one armed Man!
TazzieDevil
Postby TazzieDevil » Mon May 14, 2007 5:31 pm
UPDATE:
Have Workshop manual - will be working on preping the engine this week.
Engine swap occouring this weekend, both saturday and sunday.
If ya free, feel free to swing by. No pressure to be there.
TS Profile
TazzieDevil
Postby B1NZ » Mon May 14, 2007 6:36 pm
TazzieDevil wrote:UPDATE:
Do you need a reliable car to pick up parts? I'll bring the Subaru :lol:
Subaru GF8 Wagon
Subaru GC8 rally car project
B1NZ
Postby Dell'Orto » Mon May 14, 2007 7:02 pm
B1NZ wrote:Do you need a reliable car to pick up parts? I'll bring the Subaru :lol:
HAHAHAHAHAHAHAHAHAHAHAAAHHAHAAHAHAHAHAHAHAHA@#&@)%&*#$%*)@$(@)#$
You're funny :lol:
Postby 2LTR Rona » Mon May 14, 2007 7:27 pm
What the one leaking coolant & smoke pissing out of the bonnet scoop :lol: :lol:
2002 Altezza, 1974 KE25
2LTR Rona
Postby TazzieDevil » Tue May 15, 2007 10:03 am
I didn't wanna say anything cause my cars the one with no engine.......
That would be nice though brendon... im bound to have forgotten something small when I go to put it together again.
Im currently shopping around for a new headgasket, is a bigger thickness better than thiner? You know what they say, do it once, do it right.
Any other suggestions for replacing things?
SO far i've got;
Head Gasket,
Water Pump,
CamBelt (already got new one)
TS Profile
TazzieDevil
Postby Mr Revhead » Tue May 15, 2007 10:12 am
manifold gaskets?
Postby pc » Tue May 15, 2007 10:28 am
TazzieDevil wrote:Im currently shopping around for a new headgasket, is a bigger thickness better than thiner? You know what they say, do it once, do it right.
SO far i've got;
Head Gasket,
Water Pump,
Replace the headgasket with an original spec one. raising or lowering the compression is probably not a good idea.
replace the cambelt idler wheel thingie.
Maybe replace headbolts
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Postby Leon » Tue May 15, 2007 10:46 am
Quick question... why are you replacing the head gasket?
Postby 2LTR Rona » Tue May 15, 2007 11:02 am
Leon - he has brought a drop in engine, giving it a bit of a freshen up before it goes in as its done a few Km's (think i read that) & its better to be safe than sorry 8)
2LTR Rona
Postby TazzieDevil » Tue May 15, 2007 11:09 am
Good question Leon.
Someone mentioned replacing the gaskets. The engine im putting in has done 85,000kms.
I figured I'd go down to Repco or Supercheap at some point and grab a gasket.
So I should ask for a manifold gasket and a head gasket.
If i ask for a "cambelt idler wheel thingie" you think they might know what I want? LOL
Revhead, you still got that contact of yours that can get a good deal for some mitsi stuff?
TS Profile
TazzieDevil
Postby Mr Revhead » Tue May 15, 2007 11:19 am
go where?
dont be silly
if its done 85k then i wouldnt touch it.
yep i do
Postby TazzieDevil » Tue May 15, 2007 11:29 am
Mr Revhead wrote:go where?
dont be silly
yep i do
Sweet.... then i'll not touch it.
Now, the top is currently off the engine, exposing the cams, this was done so he could keep it all oiled without having to run it. Do I need a new rubber seal thingie? there is one on it at the moment.
I deffinitly need a new oil filter though. The one on the old motor needs replacing and the new block has an old crappy one on it atm.
TS Profile
TazzieDevil
Postby Mr Revhead » Tue May 15, 2007 11:34 am
yeah get new cam cover gaskets
Postby Silvertop » Tue May 15, 2007 11:50 am
And gasket goo! Gunk those suckers down.
Silvertop
Postby TazzieDevil » Tue May 15, 2007 11:56 am
Silvertop wrote:And gasket goo! Gunk those suckers down.
ye-arrhhh... i've got gasket glue somewhere.... but yes, good point :)
TS Profile
TazzieDevil
Postby pc » Tue May 15, 2007 1:02 pm
Opps.. I didn't read the whole post and thought you were fixing the old one. Yeah, leave the replacement together. It probably hasn't had a cambelt change, so change that and the idler/tensioner. Oils seals would be worth replacing too.
red car
Manfield - 1:24s
pc
Postby TazzieDevil » Tue May 15, 2007 2:31 pm
The old motor had new belts about 20,000ks ago,.... so those will still be good.
TS Profile
TazzieDevil
Postby B1NZ » Tue May 15, 2007 6:41 pm
Yes definatley leave it with standard bits in, I thought you had a new block only, not a whole 2nd hand engine, shouldn't be too bad then, I don't think I'm up to anything this weekend, so I may offer you my limited experience to give you a hand.
Oh and blair, :P Ours doesn't smoke or steam!!
It used to but has been fixed, normal Subaru EJ20 problems apparently
Subaru GF8 Wagon
B1NZ
Return to Wellington / Lower North Island Region
