Fitting a Steering Rack Boot...
Postby BlakJak » Sun Mar 18, 2007 8:43 am
Revhead and Mmm, boost will probably find this amusing ;)
My ST195 requires a rack boot replaced in order to pass WOF.
For budgetary reasons I'd like to see if I can do this at home, instead of paying to have it done. Catch is, i've not done it before...
... anyone with experience feel like giving us a hand? ;)
In Upper Hutt. I have a decent Carport and most of the tools I would think we'll need - just lacking in the experience department...
Want to see if I can get it done before end of week as the WOF has expired and I wanna take it back on Friday...
I'm in Trentham. The plan is Pizza for dinner, and whoever comes gets to share... proposing maybe Tuesday or Wednesday after work...
Cheers in advance :)
BlakJak
Postby strap-on » Sun Mar 18, 2007 10:40 am
Make sure you count the amount of wind's you take to undo the tie rod, then you just count the reverse when you do it back up and if your lucky you *may* get away without a wheel alignment, but would still be a good idea to get one anyway.
I would help but trentham is just a BIT to far away.(plus I'd rather stay as far away from the place as possible)
strap-on
Postby BlakJak » Sun Mar 18, 2007 11:08 am
Heh. Typical blue-suiter :P
I want to get a wheel alignment done eventually anyway...
But TY for the advice :)
BlakJak
Postby Mr Revhead » Sun Mar 18, 2007 1:09 pm
yep as above.
you will need:
1/2 inch socket set
large hammer (not a claw but a club)
a spanner set, probablt a 19mm and a 17.
pliers
side cutters.
ill know on monday if i can help, have a few things on this week.
Postby strap-on » Sun Mar 18, 2007 1:35 pm
Actually Its Joint that I wish to avoid :P,
All the stuff on rev-heads list is important, when you get your boot from repco, get them to have a look at the tie rod and get another split pin that
is exactly the same (trust me you will not be able to re-use your split pin, hence the pliers and side cutters)
a good tie rod end puller is a good idea, these are about 50 bucks for a powerbuilt one, and are worth it considering the 35 dollar fork type alternative will result in splitting the tie rod ball joint boot and you will have to shell out 50 bucks for a new tie rod. (do the math)
for examples see here http://www.powerbuilttools.co.nz/powerbuiltsteeringsuspension.htm
the fork type ones are the ones you want to avoid, but the pullers half way down the page are tops. I'm going to go buy one this avo, I would lend it to you but I'm not coming your way.
strap-on
Postby Mr Revhead » Sun Mar 18, 2007 1:43 pm
u can reuse the split pin
the sidecutters are for the zip ties on the boot :wink:
dont need the special tool. thats what the hammer is for.
however DONT smack the top of the tierod. u smack the side of the hub where it goes in.
Postby strap-on » Sun Mar 18, 2007 2:06 pm
A split pin is like 50 cents, its a good idea to replace it just cos, I suppose you can just use the hammer, but it saves a lot of four letter words if you have the toll
strap-on
Postby Mr Revhead » Sun Mar 18, 2007 2:17 pm
i was thinking of the fact he wants to save $$$
$50 would pay for it at a dealer :wink:
Postby BlakJak » Sun Mar 18, 2007 2:30 pm
Cheers Revvy.
And yes, the shoestring budget aint helpin...
I have all of the aforementioned tools cept my hammers are conventional claw type - I have a ballpean hammer but its not especially large...
BlakJak
Postby Mr Revhead » Sun Mar 18, 2007 3:03 pm
have you got a lead light?
me and dstrb will be your way tuesday night.
could drop round around 8-830.
if you can have in up with the wheel off it shouldnt take long
Postby BlakJak » Sun Mar 18, 2007 3:11 pm
I don't have a leadlight, sorry...
Got a coupla good torches :p
Thats something I should pick up, actually.. never really had a big need for a leadlight before now, as never had any space to do any of my own maintenance beyond oil changes... (only moved into this place in January)
Sweet, thanks to both of yas...
BlakJak
Postby BlakJak » Mon Mar 19, 2007 7:27 pm
Just picked up a 19mm 1/2" socket from Repco. A Crescent was far too expensive.
Also grabbed a cheap ($6!) lead light from the Red shed but didnt get the right bulbs for it, sigh!! will rectify tomorrow on the way home...
BlakJak
Postby Mr Revhead » Mon Mar 19, 2007 9:58 pm
dont sweat too much, ill bring my rally kit! :D
Postby Mr.Phreak » Mon Mar 19, 2007 10:36 pm
Your rally kit includes more than a big hammer?? :lol:
Mr.Phreak
Postby Alex B » Mon Mar 19, 2007 10:42 pm
Not from what i saw at Otago rally :lol:
Postby 2LTR Rona » Tue Mar 20, 2007 9:28 am
I know it contains a large right boot, as seen during service of the Day Breaker :lol:
2002 Altezza, 1974 KE25
2LTR Rona
Postby Mr Revhead » Tue Mar 20, 2007 9:28 am
LOL thats what you get when ya no 2 driver hits a tree :lol:
Postby BlakJak » Tue Mar 20, 2007 9:56 am
... should I be worried? :P
BlakJak
Postby Mr Revhead » Tue Mar 20, 2007 9:58 am
not unless youv hit a tree!
Postby 2LTR Rona » Tue Mar 20, 2007 10:03 am
BlakJak wrote:... should I be worried? :P
Nah its all good....Rev's service consists of opening the bonnet and kicking the front drivers side wheel :lol:
2LTR Rona
Return to Wellington / Lower North Island Region
