bodywork perk job anyone
Postby jakesae101 » Tue Sep 29, 2009 12:49 pm
doesnt have to be pretty i have failed work on rust in the gutter on my trueno in the boot part of the gutter needs to have a new peice cut out and welded in and a rust hole welded up
EX. MK2 escort 4 door 1300cc
EX. AE101 trueno gt apex
jakesae101
Postby Distrb » Tue Sep 29, 2009 1:20 pm
how close to rear screen is the hole?
Distrb
Regular Poster
Postby jakesae101 » Tue Sep 29, 2009 1:44 pm
its on the u part of the gutter on the winscreen side should be able to get a mig in there to weld the hole up
jakesae101
Postby Loudtoy » Tue Sep 29, 2009 5:56 pm
jakesae101 wrote:its on the u part of the gutter on the winscreen side should be able to get a mig in there to weld the hole up
I think what he's meaning is how close is to the screen ie will the heat from the welding be likely to crack the screen or slight warping of the welded parts cause it to crack. Pretty sure distrbs trying to figure out if the screen would need to come out to get the job done
TS Member sine 2001
Prado To tow stuff with
Rodeo to do work stuff in
Loudtoy
Postby jakesae101 » Tue Sep 29, 2009 6:05 pm
i dont think it would need to come out
jakesae101
Postby holden_fan2005 » Tue Sep 29, 2009 7:33 pm
Try and post up some pics dude with a pen or something in the photo to give an idea of distance.
holden_fan2005
Postby jakesae101 » Tue Sep 29, 2009 7:41 pm
bit hard when i dont have a digi cam at the mo and the cars in storage the rusty patch is roughly the size of a 10-20c peice but only has a small hole through tho and the rusty gutter is probibly 5-7cm at the most is rusted away where the rubber goes on and partly goes round the corner on the rhs by the rear screen
jakesae101
Postby jakesae101 » Tue Sep 29, 2009 7:56 pm
with a stolen photo hope you get the gist of it
jakesae101
Postby jakesae101 » Fri Oct 09, 2009 5:42 pm
anyone just have to do the gutter its about 7 cms in total just needs a strip of mild steel like 10mm wide welded in where there is gutter missing this is the only thing left for my wof i sanded back the suposed hole and it was just a deep rust pit about 1.5 - 2mm wide so i just painted it
jakesae101
Postby ryanfels » Fri Oct 09, 2009 6:03 pm
Why is that a WOF issue?
I had big holes in mine 2, i just cut most of the rust out and glued in some new metal under it. isnt structual and was just causing major leaks. bog over it, sand, paint and your done
ryanfels
Postby jakesae101 » Fri Oct 09, 2009 7:51 pm
thats what i was trying to figure out i had it all siliconed up because it was leaking
jakesae101
Postby DexGT » Sat Oct 10, 2009 12:26 am
Are you coming to the movie tomorrow (saturday ) ? , we can talk about it then , otherwise send me a PM with your phone number :wink:
DexGT
Return to Wellington / Lower North Island Region
