Wanted to borrow, compression tester
Postby ATAl » Thu Aug 12, 2010 11:02 am
Hey, I need to test compression on my 20 valve, but can't find a compression tester that will fit down the spark plug tube, does anyone have one I could borrow for a day?
ATAl
Postby neo » Thu Aug 12, 2010 2:14 pm
I have one that will work
If you want to turn up at my place on Sunday, hopefully I'll be working in the garage / can test it then and there
neil
027 2446696
neo
Postby ATAl » Thu Aug 12, 2010 3:48 pm
Thanks, but one small problem - the car doesn't really run and is far from road legal so I need to borrow the compression tester to use at home. Is that possible?
ATAl
Return to Wellington / Lower North Island Region
