Anyone familiar with Diesels?
Postby Nu-Del » Mon Dec 12, 2011 1:57 pm
Hi Guys
Have a LX90 Ive just put a new engine into and cant for the life of me seem to get it to start, it turns over and there seems to be fuel but Im just not sure whats wrong with it.
The car seems to be doing some weird things like when you open the door the stereo etc turn off and the hazard lights flash then after a while it all turns off so starting to get rather annoyed with it.
Any ideas?
Nu-Del
Postby Bling » Mon Dec 12, 2011 2:24 pm
Wiring is wrong somewhere i'd take a guess at. Helpful I know :P Engine check light come on at all? Had a hard starting pathfinder this morning but in the end it went so not sure what's up there either.
Postby MAGN1T » Mon Dec 12, 2011 2:25 pm
Dodgy alarm?
Steve
Computers make you go mad.
MAGN1T
!USER HAS BEEN BANNED!
Postby Nu-Del » Mon Dec 12, 2011 2:29 pm
MAGN1T wrote:Dodgy alarm?
Steve
Thats kinda what Im guessing but I have no idea how to remove it... Have emailed the old owner to see if he knows of any issues that happened befor they cooked it
Nu-Del
Postby edwagon » Mon Dec 12, 2011 2:40 pm
They have a prick of a glow plug control system on them.
Check that the glow plugs are getting 12v when you first turn the ignition on and the glow pug light comes on.
If not, check the glow plug fuse.
Did you connect up the Glow Plug resistor assembly (underside of intake manifold) Get this wrong, and you'll blow the fuse everytime....
edwagon
Postby Nu-Del » Mon Dec 12, 2011 2:56 pm
edwagon wrote:They have a prick of a glow plug control system on them.
Everything looks to be plugged in as its ment to be (its a 2LTE EFI motor if that makes any difference)
The glow plug light comes on when you turn the car on and turns off after no very long but havent checked the glow plugs themselves with a volt meter
Nu-Del
Postby strx7 » Mon Dec 12, 2011 3:51 pm
all the 2LTE's i've had anything to do with have run 7v or 9v(from memory) glow plugs they certainly dont get 12 volts to them.
Postby Nu-Del » Mon Dec 12, 2011 5:47 pm
Managed to get it started after ripping the cheap nasty looking alarm out of it :) its running a bit funny and doing a few funky things but at least it starts now
Nu-Del
Postby edwagon » Tue Dec 13, 2011 8:18 am
Ahh, yup, you're right - the plain 2L and possibly 2L-T (not e) have a 12v glow that drops down to 7v 'afterglow', and the 2L-TE have the low volt plugs.
The 12v-7v 'superglow' system has so many points of failure and is a major pain in the ass.
Glad you got it going Nu-Del
edwagon
Return to Wellington / Lower North Island Region
