after a reduction gear starter motor... for an electric bike
Postby Psycho_Dad » Fri Apr 06, 2012 9:38 am
so im bored of commuting, i live in mt cook and drive my suzuki van to karori every day, i would bike but i work as a tree surgeon and biking up to karori is too exhausting for me to then slay giants
sooooooo
im building an electric bicycle and need a reduction gear system for it... many starter motors have such a system, so wondering if anyone here has a buggered starter motor they would like to donate to the cause of science!
i can come and pick up from anywhere in welly, i kinda need to get this gearing sorted before i buy up big on lipos, motors and speed controllers
if anyone here is interested by such a proqject ill get it all photographed and documented for people to check out
should be easier to build than my sensory deprivation tank proqject
Sam I am
027 8261963
Psycho_Dad
Postby Leon » Fri Apr 06, 2012 1:59 pm
/random comment
If you have a bicycle with a total max power output of greater than 300 watts, it's a moped and the cops will have words with you about it.
Postby Psycho_Dad » Fri Apr 06, 2012 7:06 pm
cheers for that leon, i appreciate your input
300 watts off my legs on the karori hills sounds like relief to me(te aro climb kills me), my lipo battery i plan on using only has 177watt hours, so although my motor may be capable of doing such speeds, i coulid only maintain 300w for 35 min as it is
http://www.electricycle.com/index.html
is the basic plans im working off, although i am not completely sold on it yet
but it all starts with a starter motor
:D
Psycho_Dad
Postby LEAKER » Sat Apr 07, 2012 5:13 pm
Just pick a part that shit. There should be heaps out there and then you would have a choice.
The GT4 is to Celicas what the GTR is to skylines.
LEAKER
Postby 2ToneTezza » Wed May 02, 2012 3:38 pm
You'd be better off with a direct drive hub motor.
I'm in the process of building/evolving my electric bike, currently running a 72V system with a 1000w rear hub motor, not exactly legal, but the rules mean that a legal e-bike would be pretty much useless in Wellington (unless you somehow manage to stick to the flat). Mine gets me up Ngaio gorge at around 45kph pedal assisted. have a look at http://ev.geek.nz for some good info on what people are building. talk to Daryl @ www.EVlab.co.nz for motors etc (he's based in Upper Hutt).
'99 Altezza - project car
'90 Pulsar GTi - daily driver (wet)
'03 Suzuki SV650 daily driver (dry :) )
'01 KTM520EXC motard - Road reg'd motard + use as daily driver = possible loss of licence
2ToneTezza
Postby Psycho_Dad » Sun May 27, 2012 11:09 am
hey thanks 2tonetezza, sounds like you have an intense setup, my battery and stuff showed up, but i think im going to go v belt to chain drive for power so far, its a 2.7kw brushless RC motor but i want be using half of that
ill check your links, facinating stuff
Sam I am
Psycho_Dad
Postby Psycho_Dad » Sun May 27, 2012 11:15 am
is there a reason they seem to have no motors for 700c wheel size?
Psycho_Dad
Return to Wellington / Lower North Island Region
