CNC machining?
CNC machining?
Postby Dell'Orto » Sun Jun 10, 2012 6:25 pm
Is there anyone in the Wellington region who can do this? Specifically after someone to make one of these:
Brad
Postby Stott69 » Sun Jun 10, 2012 11:02 pm
Manifold flange I take it? Will ask at work tomorrow n let you know of some places to try
Stott69
Postby tenyearguarantee » Tue Jun 12, 2012 3:49 pm
try fraser fire and engineering in wingate. they have a couple guys there that should be able to help you out
tenyearguarantee
Postby wde_bdy » Tue Jun 12, 2012 3:55 pm
Aren't the plates tapered as well?
Callum
wde_bdy
Postby Dell'Orto » Tue Jun 12, 2012 7:16 pm
Possibly, its hard to tell. It looks flat in pictures? Need to ask Sheldon really
tenyearguarantee wrote:try fraser fire and engineering in wingate. they have a couple guys there that should be able to help you out
Thanks man, will give them a bell.
Postby wde_bdy » Tue Jun 12, 2012 9:57 pm
I thought the whole point of the plate was to deal with the taper created when uprighting an engine? Personally I would just give Sheldon cash to create what you need as finding anyone else in the country with half a clue on K series stuff is a pretty remote possibility.
Callum
wde_bdy
Postby Dell'Orto » Tue Jun 12, 2012 10:00 pm
I dont follow? When the motor is upright, the ports are horizontal...TRD manifolds are straight, shouldnt be a requirement for a taper?
Am awaiting a reply from ze master also 8)
Postby GOLDAE86 » Thu Jun 14, 2012 8:17 pm
What about water jetting, then tapping the threads yourself?
To finish first, first you must finish
GOLDAE86
Real Life Mechanic
Postby Dell'Orto » Thu Jun 14, 2012 8:55 pm
Yeah I was thinking water jet could also work. Talking to the man about it, they're made of 20mm thick plate, will water jet do that?
Postby Stott69 » Thu Jun 14, 2012 9:36 pm
Yea just take longer
Stott69
Postby ON PSI » Thu Jun 14, 2012 9:49 pm
christes water jet can cut up to 50mm thick
ON PSI
Postby GOLDAE86 » Fri Jun 15, 2012 10:12 am
Well the water jetter here in welly will cut 200mm with course grit.
Taking longer? Cant see how? Scan it cut out test piece out of hard board etc. check it-if all good then cut out of required material.
GOLDAE86
Real Life Mechanic
Postby TRD Man » Mon Jun 18, 2012 11:09 am
wde_bdy wrote:I thought the whole point of the plate was to deal with the taper created when uprighting an engine?Callum
The purpose of the plate is to provide secure fixing and space for both inlet & exhaust manifolds separately.
I bought one of these kits new in about 1981 and replicated the plate on a milling machine.
From memory the inlets aren't tapered but they are angled both downwards and inwards.
Do you have a template to work with?
TRD Man
Postby Dell'Orto » Tue Jun 19, 2012 9:53 pm
No I don't, was hoping to get dimensions/one made. Did you get the bellhousing too Bruce, or just the manifolds?
Postby TRD Man » Tue Jun 19, 2012 10:51 pm
I got the whole kit. Bloody expensive it was. There wasn't a bellhousing. If i remember correctly the gearbox leant over with the motor. There was a trianglulated bracket to attach to the crossmember and we bent the gearlever to suit. I've still got all the Tosco catalogues and spec sheets here so I'll check.
The manifolds themselves were about 6 or 7 hundred from memory but the plate was about 9 hundred which is why we made another one.
TRD Man
Postby Dell'Orto » Wed Jun 20, 2012 9:30 pm
Interesting...I believe there was an upright bellhousing, but that may have only been for the TS cup cars perhaps.
Would love to see the Tosco catalogues if you can ever scan and upload them.
Postby TRD Man » Thu Jun 21, 2012 12:47 pm
I'm 99% certain there was not a bell housing made by Tosco. I cannot tell you about something aftermarket made later.
TRD Man
Return to Wellington / Lower North Island Region
