3s-ge head replacement
Postby bogan89 » Mon Dec 26, 2005 2:01 am
has any 1 done a head change on 1 of these im a bit stuck tryin 2 remove the efi system any tips would help or if u wanna help me do it that would be much appreciated.
no one suspects the quiet ones
bogan89
3s
Postby JasonZE » Mon Dec 26, 2005 10:27 am
Make sure you remove the steel bracket from the back of the manifold to the bottom of the block!
What other problems are you having with the efi?
JasonZE
Real Life Mechanic
Postby bogan89 » Mon Dec 26, 2005 12:42 pm
im having shit loads of broblems like locating all the bolts holding it 2 the manifold and once i get that off my next problem is 1 of the cams slipped when i was undoing the cam pulley which will of moved my timming and i got no timing cover any other tips u can give me will also help
bogan89
Return to Christchurch / Upper South Island Region
