Where to get Injectors cleaned
Postby FST4RD » Fri Feb 03, 2006 1:25 pm
I just aquired some 510cc evo injectors and was going to get them cleaned before installing them.
Where in Chch can people recommend me to and how much??
Thanks
1983 Mitsubishi Starion
1995 Subaru legacy GT SW
FST4RD
Postby aesc » Fri Feb 03, 2006 1:30 pm
Install them, fill your tank with petrol, put fuel injector cleaner in tank, thrash your car for that tank and your injectors will magically be cleaned :P
EX AE101 owner
2013 Ford Focus ST
aesc
Postby FST4RD » Fri Feb 03, 2006 3:31 pm
Your a genius blair........ hehehe :D
FST4RD
Postby aesc » Fri Feb 03, 2006 3:35 pm
Na but seriously wouldnt getting them flow tested pretty much clean them at the same time?.... I dunno :?
EX AE101 owner
2013 Ford Focus ST
aesc
Postby JT » Fri Feb 03, 2006 4:43 pm
Have you got an aftermarket ECU ?
I think NZEFI do injector clean and test, could re-tune it as well ;)
JT
Postby FST4RD » Fri Feb 03, 2006 5:52 pm
Got the Evo injectors, evo ecu with a gizzmo chip, TD05, just need the Evo AFM and i'll be away laughing!!!
Thats the good thing about Mitsi, they're like lego, all the bits fit across the range!!! :D
FST4RD
Postby diss7 » Fri Feb 03, 2006 5:57 pm
Are you sure an evo ecu will run on a gsr motor?
And even if it ran it, its 200cc smaller, so will over fuel it etc etc
diss7
Postby rallymazda » Fri Feb 03, 2006 6:20 pm
my dad (lichfield motors) has a machine for flushing injectors, they need to be installed first, did it on the levin and could feel a difference
[4AGE8U] << my old number plate
Got me a new altezza, now arrived
1991 corolla wagon- work hack
rallymazda
Postby FST4RD » Fri Feb 03, 2006 10:20 pm
Yeah it's a common as conversion, get the Evo injectors, AFM, ECU, Fuel pump and turbo, all straight bolt up apart from the down pipe of the turbo (easy fix) and your away laughing!!!
FST4RD
Postby Ako » Sat Feb 04, 2006 10:22 am
Runs on airflow signal, so the capacity makes no difference.
Don't just assume it will work 100% though, a few people have had issues with them starting to detonate for no apparent reason. Plus the 1800 is a horrible horrible little bastard to begin with and all deserve to DIE
Ako
Postby FST4RD » Sat Feb 04, 2006 4:19 pm
Yeah I'm going to get an adjustable fuel pressure regulator and guage and what not...
It's going to do untill i can afford to get a 4G63 block and head to drop in, only need the bare block as I got most of the bolt on parts at home.
FST4RD
Postby matt dunn » Mon Feb 06, 2006 8:27 pm
aesc wrote:Na but seriously wouldnt getting them flow tested pretty much clean them at the same time?.... I dunno :?
rallymazda wrote:my dad (lichfield motors) has a machine for flushing injectors, they need to be installed first, did it on the levin and could feel a difference
No, and No.
They have wee micro filters in the top of them to catch the dirt and stuff.
How do you expect it to come out unless you reverse flush them?
We do them at work.
Flow test them first on open flow and pulsed flow (to check closing spring operation)
then 1 hr in the ultrasonic cleaner,
then flow test fluid through them in the reverse direction to flush the krap out of them.
Then re-test them again on open flow and pulsed flow.
Matt
Postby FST4RD » Mon Feb 06, 2006 9:46 pm
We do them at work.
How much does that cost??
FST4RD
Postby matt dunn » Mon Feb 06, 2006 10:16 pm
Normal price is $25+gst each.
Return to Christchurch / Upper South Island Region
