NZEFi Dyno Day 19th March... WITH PRIZES!!
Postby mister2 » Thu Mar 09, 2006 2:24 pm
Hi,
NZEFi is running a dyno day on Sunday 19th March, 11am onwards. Come and test the power of your car! Power, Torque, Boost and optional Air Fuel Ratio plots against RPM.
2WD - $40
4WD - $70
w/AFR +$20
The dyno is NZEFi's new 4WD Dynapack hub system (2000's + 3000's) so can handle big HP with no wheelslip!
There will be prizes in the following categories:
- Overall Highest Power
- Highest Specific Output NA (HP/L)
- Highest Specific Output Boosted (HP/L)
We'll have the BBQ going, so come on down to NZEFi - 37b Carlyle St, Sydenham (near Repco Gasson St).
Cheers!
Nick
www.nzefi.com
4WD Dynapack Dynamometer.
Link, MoTeC, Greddy, Power FC sales support and tuning.
Weapon of Choice: 1992 NSR250 SE
On hiatus, current location: Cambridge, UK
mister2
Postby IH8TEC » Thu Mar 09, 2006 5:51 pm
how much is it for a couple of runs on the dyno normally? ie not on a dyno day, probably need about 3-4 quick runs with af and boost plot
Postby mister2 » Fri Mar 10, 2006 8:56 am
From our website: www.nzefi.com
$60 2WD Dyno Runs
$90 4WD Dyno Runs
+$20 ...with printout of air fuel ratio vs. rpm (measured using a five-wire Bosch wideband sensor)
+$20 ...with exhaust backpressure measurement
+$20 ...with intercooler pressure drop measurement
+$20 ...with fuel pressure measurement
Nick
www.nzefi.com
mister2
Postby mister2 » Thu Mar 16, 2006 4:40 pm
It's going to be a pretty good day, hope to see a few of you there!
Matt's said he's going to bring the mighty Focus up for a run so that should be worth watching :)
Nick
www.nzefi.com
mister2
Postby Ako » Fri Mar 17, 2006 2:27 pm
Anyone coming down to prove their car really is as grunty as they say it is?
Ako
Postby mr pad » Fri Mar 17, 2006 3:03 pm
Ako wrote:Anyone coming down to prove their car really is as grunty as they say it is?
Im going to try to come down and watch, but wouldn't want to shame anyone out with the power of 3au.
mr pad
Return to Christchurch / Upper South Island Region
