need work done on your car? cheap!
Postby rwd_mayhem » Wed Dec 17, 2008 12:22 pm
need to earn some extra money so if you need anything done to your car i am willing to help out, for a small charge of course but will be much cheaper than any mechanic. I can get parts at trade price too so that makes it even cheaper.
I am not a qualified mechanic therefore i will do simple things like:
* Brake Pads/ Shoes
* Oil and Filter change
* Suspension parts (tie rod ends, springs etc)
* Cooling system (hoses, waterpump etc)
* Fanbelts/Power Steering belts/air con belts (not cambelt)
* Ignition system (spark plugs, dizzy cap/rotor, leads etc)
* Wheel Bearings (not pressed on ones)
* Slave Cylinders/Master Cylinders/Wheel Cylinders
* Glow Plugs
* Fuel Pumps
* Bushes/Mounts
* Seals
* Lights/Panels/Locks etc
* Filters (air, fuel etc)
* Clutch (only rwds)
* Fluid Changes (Antifreeze, ATF etc)
And probably more things, just need to ask. So if you or anyone you know needs anything done, either PM me or for a quicker response text me on 0273252714.
Cheers,
Liam.
current: 1975 Valiant Regel
previous: 1980 mazda 626, 4AGE AE70 sedan, AE70 sedan, mk2 escort, KP60 starlet, TE71 liftback X2
rwd_mayhem
Postby blackie » Fri Dec 19, 2008 1:53 pm
I need to get my cv joints replaced (Honda Accord), can you do that?
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1892
When my bros call.. dey get hit wit da chinnggggaayyy
blackie
Return to Christchurch / Upper South Island Region
