Reseting Leafs
Reseting Leafs
Postby BlackST185 » Fri Mar 12, 2010 4:33 pm
Hello all,
Anyone know of a good place to get my leafs reset for my 81 KE70 sedan? In Christchurch obviously.
I wanna lower my KE70 but not have to shorten shocks. Also what are some good front springs? Kings, Cobras etc?
I don't want to compress my standard springs or use lowering blocks without reseting my leaf suspension.
Any advice, comments and ideas welcome!
Thanks!
BlackST185
Postby Elmo » Fri Mar 12, 2010 5:08 pm
Bellamy and East will make alter or reset Springs. A lot of work shops round Chch use them.
http://www.springs.co.nz/
Elmo
Postby Rob_GTZ » Sat Mar 13, 2010 3:46 pm
KE70 Sedans don't have leaf springs, only wagons have leaf springs. Sedans and Liftbacks have coils all round.
You have various options depending on your budget & what you want to use the car for. Compressed standards is obviously the cheapest option. Any aftermarket springs are a good option, but you can only lower about 30mm in front of a KE70 with standard shocks. Alternative to shortening standard shocks ( Which are probably worn out anyway, unlesss recently replaced) is to use a shorter shock, intended for a different model. For example KE70 Wagon Rear Shocks are 80mm shorter than sedan shocks, using them in a sedan allows you to go much lower & keep your spring captive. There are heaps of options for front shocks depending on how low you want to go
Rob_GTZ
Postby BlackST185 » Wed Mar 17, 2010 4:28 pm
Thanks guys!
Would the best option for the rear be new kyb wagon shocks with aftermarket springs?
BlackST185
Return to Christchurch / Upper South Island Region
