WTD: KE20 K series engine mounts & water outlet housing
Postby crispy'86 » Sat May 01, 2010 8:45 pm
As topic states i'm desperately seeking a pair of engine mounts for a 3k out of a ke20. Doing an engine swap for a friend and the mounts on the 3k that's going to go in, look to be off a ke70 or similar k series?
Engine backing plate between block and flywheel etc, water outlet housing at the back of the head, not sure if they are all the same but this one is a 90 degree one, outlet is facing the passenger side. Anyway let me know what you have asap please, this would be much appreciated if i could get hold of some of these this weekend if possible.
Either pm , reply or get hold of me on 021 129 7777 or 0274 351 474
Thanks heaps guys :D
in Christchurch too if anyone local has any lying round
crispy'86
Return to Christchurch / Upper South Island Region
