where to get cert in chch
Postby h8wrxs » Sun Jul 24, 2011 2:03 am
my trueno just failed its warrant on the rear shocks so its time to put my new coilovers in and fit all the other bits ive bought recently (i will eventually put it in my project thread)
but im going to need to cert for a my coilovers and my new brakes
wheres a good place to go to and what sort of things do they check over when they do it? what do most cars fail on?
ive never gotten cert on one of my cars before so i dont know much about it
h8wrxs
Postby Elmo » Sun Jul 24, 2011 10:15 am
Theres two people
Wayne Martin is one
11 Waller Tce
Vehicle Certification Services Ltd
ph 365 4777
I think is his contact details
And Don Hoff is the other
Some people have preferences, Ive dealt with Wayne before and seems ok.
Elmo
Postby 7ishNZ » Sun Jul 24, 2011 11:18 am
+1 for Wayne
7ish
7ishNZ
Postby h8wrxs » Sun Jul 24, 2011 4:12 pm
sweet as, thanks
what do they actually do in the cert? is it just like a warrant?
h8wrxs
Postby Elmo » Sun Jul 24, 2011 4:48 pm
There are certain requirements to obtaining a cert on an item. They only look at the items that YOU ask, or require to be cert'ed.
An example is, seat belt mounts. They require a minimum sized plate on each side of the 'floor pan' where belt is to be mounted. Plate has to have radius'd corners and thickness etc.
If getting a cert, from memory you get most items done under a one off fee. Some more extensive items are a little higher priced as require more work.
Elmo
Postby d1 mule » Sun Jul 24, 2011 10:44 pm
iv delt with wayne and don. i prefer don but thats just me. is just like a very tough wof, the only look at the stuff you have changed but is fonething is dodgy they will fail you. you have 3 months to do the repairs.
they are about $350
d1 mule
Return to Christchurch / Upper South Island Region
