After some internally threaded rod- Chch
Postby crispy'86 » Wed Dec 21, 2011 1:48 pm
As above i'm trying my luck to find some internally threaded rod for a little tool i'm lookng at making. Ideally if it's cheap enough to do so make a crank installation tool for motorbikes saying i've stripped one. Haven't got much else to keep me entertained while i'm off work so gave this a thought. M10 x 1.5 thread pitch and about 140mm long. Was thinking blacks but not sure they have internal threaded stuff only externally threaded rod. Any suggestions where i should look/try?
crispy'86
Postby Elmo » Wed Dec 21, 2011 5:52 pm
Im guessing you wont find any, you have to make something, wouldnt be hard unless you need it threaded realy deep for some reason.
Elmo
Postby fangsport » Wed Dec 21, 2011 6:52 pm
pinch a steering rod.
the balljionts thread into M10 one some vehicles
fangsport
Postby metric » Wed Dec 21, 2011 7:26 pm
They also have connectors in the "unistrut" range might be something in there
metric
Postby Rob_GTZ » Wed Dec 21, 2011 8:32 pm
What outside diameter can you get away with/does it matter? Can make something up easy as
Rob_GTZ
Postby crispy'86 » Wed Dec 21, 2011 9:02 pm
That i have yet to figure out and confirm the actual thread. Ive got a feeling it's maybe more like M8 but will have to work out this, along with outer diameter of it and sleeve to put it on. Like an idea is to have something 50mm approx outside diameter and something like 12mm on inside but, as i said it needs some more thought.
crispy'86
Return to Christchurch / Upper South Island Region
