Hamilton members needing diagnostics
Postby chrisarmo86 » Fri Oct 16, 2009 7:42 pm
I just received my copy of PCMScan today. If anyone in the hamilton area wants to do some diagnostics, pm me. I am available weekends.
The program can do:
Dyno Graphs
Engine sensor diagnostics
OBD-II diagnostics
Fault codes
o2 sensor testing
etc etc etc
Google PCMScan if you want to know more about what it can do
Cheers!
My engine wants to be a 3SGTE when it grows up
chrisarmo86
Postby GTTpower » Sat Oct 17, 2009 7:14 am
One of the mods please shift this to the Hamilton section :)
1999 SXE10 Altezza RS200Z
2004 Honda SCV100
Previous: 1993 EP85 Starlet, 1984 KP60 Starlet
Steam/Origin ID: nzEP85
GTTpower
Postby AceSniper » Sat Oct 17, 2009 9:48 am
do any toyotas use a normal obd2 plug? (I have a scanner but cant think of any toyotas iv seen with the std type obd2 plug)
AceSniper
Postby fivebob » Sat Oct 17, 2009 11:23 am
The later ones (>'96) have the plug but a lot of the cheaper interfaces don't support the protocol that Toyota used.
The good news is that for most diagnostics you don't need a scanner, they still support the OBD-1 flashing Check engine light.
Also I'd be very wary of claims of producing an accurate dyno plot. They are more use for comparing changes in your specific vehicle that actually producing accurate figures.
Return to Hamilton / Waikato Region
