ps power
ps power
Postby LEV_101 » Wed Mar 08, 2006 1:11 pm
the apexi rsm is so fun ... got so much cool things to play around with.
when i played with the ps power ... i got a bit lost ...
it has this curve graph thing and has 1ps 10km/h 2ps 20km/h so on to .... 130ps 190km/h
what the hell does that mean...
any help would be great
LEV_101
Postby ollieboy » Wed Mar 08, 2006 2:07 pm
Would it be referring to metric horsepower?
ollieboy
Postby Adydas » Wed Mar 08, 2006 5:54 pm
it Is refering to PS, very close mesurement to KW( Kilowatts) i think you should find.
If setup correctly ( using the G sensor etc ) it will give a fairly close KW out put of your car, Requires ACCURATE setup of the Gearbox setup As well as the G sensor.
Adydas
Postby ollieboy » Wed Mar 08, 2006 6:19 pm
Adydas wrote:it Is refering to PS, very close mesurement to KW( Kilowatts) i think you should find.
Its closer to Hp than Kw because my car is 100ps but 75Kw and I think about 98hp or something but I will have to check that.
ollieboy
Postby Timmo » Thu Mar 09, 2006 10:13 am
Yep, PS is very close to HP (1 PS = 0.9863201652997627 hp (SAE) to be exact).....it actually is a German term (Pferdestärke = horse strength)
Basically its metric horsepower although its obsolete now (replaced by the Kilowatt)....You still see it being used on Japanese cars a lot though (ie on Gran Turismo the HP is shown as PS)
Lightweight baby
1991 MX5 Supercharged
Timmo
Postby LEV_101 » Thu Mar 09, 2006 11:23 pm
thanks for the reply guys...
but doesnt hp/ps mean the power of the engine? not meaning how much power you get at a certain speed...?
so does that mean, i have 1 hp/ps at 10km/h ...
thanks
LEV_101
Postby barryogen » Fri Mar 10, 2006 8:18 am
LEV_101 wrote:but doesnt hp/ps mean the power of the engine? not meaning how much power you get at a certain speed...?
The amount of HP/Ps your car has will vary as it goes through it's rev range, it shouldn't/doesn't pertain to a particular speed, but I guess if this little device is smart enough it could be mapping revs to G forces then it may be able to figure it out... but I doubt if it could do that.
according to that thing, yeah, but I think it is probably wrong
barryogen
2ZZ Guru in training
