$400 clutch? what to buy from where?
Postby Psycho_Dad » Mon Dec 18, 2006 6:34 am
i have $400, id like to buy a clutch, for a 4agte thats going to be around 200hpatw
will this get me a reasonable clutch? does someone here know exactly what i should buy and from where, i really want a new clutch, thanks for your time
PEace
Psycho_Dad
Psycho_Dad
Postby no_8wire » Mon Dec 18, 2006 7:34 am
Do you want a new pressure plate etc or just the actual clutch plate?
Give Trade Parts a call...they have good stuff at good prices and no I dont work there... :lol:
no_8wire
Postby big_boy » Mon Dec 18, 2006 8:33 am
i got mine for $413 or something like that its a exide 4 puck stage 3 button clutch with a 2850lb presure plate & a needle roller thurst berring
in case your woundering with button clutches
stage 3 is a comspite plate with torssion springs (the easy one to drive :P)
stage 2 is a comspite plate with solid centre
& stage 1 is a brass plates with a solid centre
big_boy
Postby Dell'Orto » Mon Dec 18, 2006 9:48 am
big_boy wrote:i got mine for $413 or something like that its a exide 4 puck stage 3 button clutch with a 2850lb presure plate & a needle roller thurst berring
An Exide clutch eh? Didnt know they'd branched out from batteries :lol:
$400 wont get you much, but go to some specialist clutch places, they should be able to do you some sort of deal.
Postby Akane » Mon Dec 18, 2006 9:57 am
$400 should get you a metallic clutch disc.
You can use your factory pressure plate.
Postby diss7 » Mon Dec 18, 2006 11:04 am
Ring Tony @ Clutch Systems in Christchurch a call. His number is 03 366 8494
I've bought 5 or 6 clutch kits from him over the years.
His prices are so good, there are users on trademe who resell his kits for twice the price.
A couple of weeks ago I got a Exedy 4 Puk Ceramic kit (clutch + Pressure + bearing) for my silvia for under $400. Had my first event on it on Saturday and its great. It even held 24pound when my actuator hose came off, heh.
diss7
Postby big_boy » Mon Dec 18, 2006 4:03 pm
woops Exedy
big_boy
Postby IH8TEC » Mon Dec 18, 2006 5:16 pm
woops Exedy
for what car? becuase 2850lb is major overkill for a 4age series motor,
Postby Quint » Mon Dec 18, 2006 8:18 pm
i paid 380 for my 4 puck ceramic buttoned PBR clutch and P/Plate.
Got mine from part master >_<
Quint
Postby Psycho_Dad » Mon Dec 18, 2006 9:52 pm
thanks heaps on the info guys, ill give tony at clutch systems a call tomorrow and see where i end up
appreciate the ideas and opinions
Psycho_Dad
Psycho_Dad
Postby Kender » Mon Dec 18, 2006 10:22 pm
A few years ago I needed to upgrade the clutch in my S/C Aw11. I went to Repco and bought a standard Corolla/MR2 friction plate and an upgraded cover plate. Back then the cover plate cost me $250 at trade price. I'm still running this combination, and it shows no signs of slipping (the wheels always spin first :) ) I found this setup provides a factory feel clutch (easy to drive on the road), with the holding power of a fancy aftermarket clutch.
'84 AW11 SC racecar "RDDWRF"
'92 SW20 GT-S
'91 GT Legacy wagon
Kender
Postby slighty_looney » Mon Dec 18, 2006 10:41 pm
id go for the exceddy 4puc, it will handle the 4agte and yea there around 413$ that what i brought for my 4agte project, i ended up still putting it in my 4age non turbo tho :P
FC3S
Robinson Steel Fabrications
Current Ride: 88 rx7
Project: viewtopic.php?t=88412
Discussion: viewtopic.php?t=88413
slighty_looney
Postby big_boy » Mon Dec 18, 2006 11:00 pm
4AGE red top small port with a S/C running 11 PSI
big_boy
Postby Akane » Tue Dec 19, 2006 5:21 am
diss1dent wrote:A couple of weeks ago I got a Exedy 4 Puk Ceramic kit (clutch + Pressure + bearing) for my silvia for under $400
Is that his retail? If it is then that's a good price.
Postby Arthanon » Tue Dec 19, 2006 7:51 am
Try your local BNT
They do cheapish clutches.
Current Ride: 1998 GT Caldina 3S-GE BEAMS Goodness
Previous Ride: 1994 Curren 3S-FE Not so Goodness
Arthanon
Postby flygt4 » Tue Dec 19, 2006 9:39 am
get a standard 4agze disc and just upgrade the pressure plate slightly.
ive used this combo for 18 months of serious abuse, 2 manfield track days,3 outings to the drags, 3 hard dyno sessions, heaps of street abuse etc and the disc is only just rooted now, and it stil doesnt slip. ive a fair bit more than 200hp atw too.
flygt4
Postby Si » Tue Dec 19, 2006 9:04 pm
my TRD race faced plate and TRD pressure plate was about 1400$....
:P
Current: , '96 SubaruImpreza
Si
