MSNZ motorsport authority card / roll cage Homologation
Postby TWSTD » Wed Dec 13, 2006 9:20 am
Mornign all.
Ok - ive got this wad of papers in front of me that I need to get completed and sent off.
1) The first is the MSNZ roll cage homologation forms. These have been filled out except Section 8 - which looks like it needs to be filled out by a "technical officer or technical advisor" - who would I go to to get this done? Anyone one here on TS able to do it?
2) The second is the Authority Card Application Form. Sections 2 and 3 also look like they need completing by an MSNZ Technical officer or Liscenced Scrutineer. Anyone here able to do this for me?
3) The third is the Compeition liscence application form. Now its a little unclear - but do I need to sit any form of test for a club spot liscence? Or I just pay the $60?
Cheers :-)
AL
@@@ Online store NOW OPEN! @@@
Click here!
DPR | HTS | SARD | WALBRO | GARRETT | SPEC | EXEDY | MINTEX | HKS | APEXi | MAPECU | SIMOTA + more!
TWSTD
Postby sergei » Wed Dec 13, 2006 9:31 am
Are you are member of a NZMS affiliated club? If so, you can get clubsport licence by filling a form (which I assume you have), sign it off by a club official, and send it with a check for $60 to address stated on the form...
Postby KE20 » Wed Dec 13, 2006 9:39 am
for the homologation. who built it.
if you did or your mate, you sign every thing as you built it and you know how it was welded, what tube and every thing, if someone else built it, and you dont know who it is, or what tube was used or anything, then youll need to email msnz and find someone near you thats a technical advisor to check it and sign.
Garage Dori
current cars; , 2JZGE-YN57R Hilux double cab, Ipsum Sport, 1948 Ford F1
prevous cars; JZX81 X2, LX80, , 1JZGTE-JZX81, KE20-3SGTE, KE35-4AGE, KE35-3A, KE30, KE36, TE71, AE85, AE86, KE70 X4, KE20, 1JZGE-VVTI-JZX100, GX90, CT170, VW(beetle) x 5,(Kombi) x 2, mazdas x heaps, +more
KE20
Postby Distrb » Wed Dec 13, 2006 9:40 am
For the licence, just fill it out, and send it off with your $$, no test required
Best just to flick Leon a Pm on here, as it will be him that will end up with your paper work on his desk
Distrb
Regular Poster
Re: MSNZ motorsport authority card / roll cage Homologation
Postby Leon » Wed Dec 13, 2006 9:42 am
TWSTD wrote:1) The first is the MSNZ roll cage homologation forms. These have been filled out except Section 8 - which looks like it needs to be filled out by a "technical officer or technical advisor" - who would I go to to get this done? Anyone one here on TS able to do it?
Now, you just knew I was going to answer this ....
1) Read section 8 again ... "where the manufacturer is unknown and/or construction data is unavailable". If your constructor has filled out the homologation form then Section 8 isn't used.
2) Authority Card is filled in by an "A" licence scrutineer or tech officer. Talk to your car club about who in the club do it.
3) You pay $60 and either have your car club committee person sign it off, or submit that form along with a copy of your car club membership card. No exam for Clubsport.
4) You do have a logbook form there too don't you? If not, you'll need to do one.
5) Don't leave it too close to Christmas, as I'm not here 22 Dec until about 3 January
6) Yes, I'm the person who does this for a job :)
Postby TRD Man » Wed Dec 13, 2006 10:23 am
Leon, your office recently issued a release about homologation of painted rollcages.
If one should have a rollcage that is already painted and has no photos of it prior to painting, and wishes to get this homologated, is there any way other than stripping the paint back off?
If it were built by, say, Possum Bourne Motorsport, would a declaration from that company about the standard of welding hold any sway?
TRD Man
Postby Leon » Wed Dec 13, 2006 10:27 am
First step would be to get a really crash hot set of photo's, so we can see as best as possible what we're looking at.
Second step, if we were in doubt still, would be to get a Tech Officer inspection done.
Third step, should we still be unsure, is the paint removal stage.
So don't start to panic just yet, but sharpen up your photography skills as best as possible.
Postby TWSTD » Wed Dec 13, 2006 10:39 am
Thanks for the responses everyone :-)
Leon - yes i did indeed misread the section 8 of the homolgation form :oops: The rest of the form has been filled out by the cage fabricator and photos attached etc.
Yes I also have a log book form - all filled out ready to go.
Yes I am a member of an MSNZ affiliated club. I will contact the club regarding getting the Authority card form signed off.
Cheers :-)
AL
Click here!
TWSTD
Postby NA Drifter » Wed Dec 13, 2006 4:08 pm
Leon, what need to be done to paper works etc if I decided to add a few more bar here and there and get the guy who build the cage to add them..?
Keith
NA Drifter
Postby Leon » Wed Dec 13, 2006 4:16 pm
Roll Protection Extension
Click me
Postby Caveman » Wed Dec 13, 2006 6:34 pm
Do it quickly because new motorsport rules are coming out which means the pipe must be welding all the way around.
Although I think this is a very good idea it also means you need to cut holes in the floor to drop the cage to weld the tops (where the roof would usually be in your way)
If you car isnt done like this get all the paper work and auditing done now. Im not sure what date the rules come into effect but if you get it audited after they come into effect you may need to do a whole lot extra work (if you havnt welded the tops already that is)
leon can confirm date
AW11 Track Toy
Formerly known as 1998
Caveman
Postby Leon » Wed Dec 13, 2006 7:11 pm
Nope, you've been listening to rumours.
I think you may just be getting mislead by the fact that a bunch of cars have recently been pulled up for having bits of weld missing (or simply insufficient weld), rather than any change of rule.
Just a case of poor workmanship leading to people needing to have stuff fixed.
Postby Caveman » Wed Dec 13, 2006 7:55 pm
Leon wrote:Nope, you've been listening to rumours.
Yes I have heard of people being pulled up for insufficient welds.
I have also heard from our club scrutineer that there will be a rule change in the future that all pipe will have to be welded all the way around. This came up at a recent scrutineer meeting.
I guess I have been misslead, you would be the authority on all of this.
AW11 Track Toy
Caveman
Postby Leon » Wed Dec 13, 2006 9:58 pm
I think it would be fair to say that scrutineers will be expecting better cage construction 8) You should see some of the absolute rubbish that hits my desk :x there are some awful cages out there, and the less of the rubbish ones the better.
Postby fangsport » Wed Dec 13, 2006 10:29 pm
while on the subject of authority cards/cages etc, is it possible to renew my licence early so i can get an new authority card that dosn't expire in 2-3 months time?
i'm sick of driving the POS van, when the Levin makes for a better summer cruiser, and is in the carport feeling very unloved 8)
fangsport
Postby Leon » Thu Dec 14, 2006 9:29 am
Yep, but you're going to need to bung a post it on the renewal to request a change of licence renewal date.
When's it up for renewal, as we are limited by the FIA as to how many months we can issue a licence for.
Postby TWSTD » Mon Mar 19, 2007 12:52 pm
Hi Leon.
I finally sent my paperwork off late last week - so i guess it should come across your desk some time in the next day or two :-) Once you have the following information can you please PM it to me as i need it for an entry form:
1) MSNZ liscence number
2) MSNZ authority card number
Many thanks!
AL
Click here!
TWSTD
Postby Distrb » Mon Mar 19, 2007 1:51 pm
Leon is out of the country till the 24th of this month. Not sure if they have anyone assigned to complete paperwork in the time he is away, but my guess is not..
Distrb
Regular Poster
Users browsing this forum: Bing [Bot] and 38 guests
