water leak
water leak
Postby Nezza » Sat Aug 09, 2008 10:28 pm
After heavy rain the drivers mat becomes saturated with water and i can't find where its coming from? anone else had similar issues
Nezza
Postby Nuty|Mike » Sat Aug 09, 2008 10:41 pm
depends what sort of car it is ?
05 Mazda Verisa .....for the Family
Nuty|Mike
Postby pc » Sat Aug 09, 2008 11:37 pm
probably a rust hole around the windscreen or somewhere down the A pillar.
If you pull the carpet out and look for a trail of water, that can help locate the source of the leak.
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Postby Nezza » Sat Aug 09, 2008 11:45 pm
Nuty|Mike wrote:depends what sort of car it is ?
Toyota hilux surf 1990
Nezza
water leak
Postby ST205 GT4 NZ New Group A » Sun Aug 10, 2008 6:23 pm
Take front panel off front of Rux. You will see rust hole in the box section at intersection between pillar and body.
Pay some one to cut out the rust and replace. Sealer on seams too.
Good Luck
Users browsing this forum: Bing [Bot] and 36 guests
