supra build update
Postby IH8TEC » Fri Dec 19, 2008 8:36 am
guys on toymods swear by the redline stuff for their w series and r154 is it? there was a recent thread on it in their forum.
i'm sure i didn't pay that, i get it somewhat cheaper because i'm in the airforce and we get a deal with BNT, around $22 per qt. i needed 4 for my e series box.
Postby cat007 » Fri Dec 19, 2008 9:50 am
W series takes 2.3 IIRC......
I might try and stop by STA on the way to Hamilton tomorrow :)
Postby postfach » Fri Dec 19, 2008 10:03 am
W5x take 2.6 litres.
postfach
Postby avinesh » Mon Dec 22, 2008 9:53 pm
Bazda wrote:
avinesh wrote:
Lith wrote:
Py7h0n wrote:Micky ET Streets
Is that what Avinesh was running too?
yea but my 60foot was sh*t..... :(
what psi were u running in the tyres.
Also with These tyres you can afford to launch at high rpm and let it wheel spin a bit cos the tyres will grip!
I launch at 5500rpm with the same tyres on my FWD.
bazda do you run a puk clutch or single plate
220.1 rwkw
jzz30 bpu soarer auto = 13.3 @ 171 km/h
jza80 supra = 11.7
jza80 apu supra manual = 400rwkw
avinesh
Postby Bazda » Mon Dec 22, 2008 10:38 pm
Neither
I run a twin plate clutch :)
Postby avinesh » Tue Dec 23, 2008 12:27 am
is it like a button like on an off???
220.1 rwkw
jza80 supra = 11.7
avinesh
Postby Bazda » Tue Dec 23, 2008 7:21 am
avinesh wrote:is it like a button like on an off???
Well i'm used to it now so it kinda just feels like a normal clutch to me lol.
To me its not that bad at all. I got the rallypak version which has really thick plates therefore you can slip it alot more than the normal twin plate clutches.
It is much harder on your drive train, you have to rev match when you down shift, and you cant just dump the clutch on a launch with drag tyres (well I cant I snap cvs or drive shafts) might be diff with a rwd though.
Postby Py7h0n » Tue Dec 23, 2008 7:48 am
Don't use Royal Purple in R154's or W5x boxs. Not worth it.
BNT Trade for Redline is about $16-$20 a bottle depending how nice they are feeling on the day. I know cause I've had it for $16/bottle :)
MrOizo wrote:Could always do a read up on the Royal Purple. Its reccommended for the 6 Speeds. should be something out there for the W5X's.
Its about $15/L!! nice and cheap! (STA Parts)
Have a read on supramania / supraforums!
Py7h0n
Postby avinesh » Tue Dec 23, 2008 5:02 pm
wats the best clutch to get for drag racing an daily driving my puk clutch is soo annoying its on an off an shudders... i hate it
220.1 rwkw
jza80 supra = 11.7
avinesh
Postby Dell'Orto » Tue Dec 23, 2008 6:30 pm
You're pretty limited with the torque your engine will produce, a multiplate clutch is really your only other option.
Postby avinesh » Tue Dec 23, 2008 6:35 pm
Dell'Orto wrote:You're pretty limited with the torque your engine will produce, a multiplate clutch is really your only other option.
is it a lot better then puk clutchs for drivability........
220.1 rwkw
jza80 supra = 11.7
avinesh
Postby Dell'Orto » Tue Dec 23, 2008 6:37 pm
Can be, yep. Seems different brands are harsher than others.
Postby xsspeed » Tue Dec 23, 2008 6:44 pm
Yeah with your engine and those power figures I would def invest in a multi-plate clutch. Most should help with driveability, plenty of people driving the likes of manual Ford F6's/typhoons without any problems
Postby IH8TEC » Tue Dec 23, 2008 7:35 pm
guys in the states say carbon/carbon twin plate clutches are the way to go, apparently really smooth, take the punishment, last a long time,
but you get what you pay for, they aren't cheap.
Postby flygt4 » Tue Dec 23, 2008 7:57 pm
xsspeed wrote:Yeah with your engine and those power figures I would def invest in a multi-plate clutch. Most should help with driveability, plenty of people driving the likes of manual Ford F6's/typhoons without any problems
i think ford had clutch issues to start with and had to rectify it? i think they got it sorted though. correct me if im wrong.
definately get what you pay for. people i know with mega $$$ HKS twin plates etc claimed they were great to drive, and the cars never jerked or rattled when i was passenger.
flygt4
Postby Bazda » Tue Dec 23, 2008 10:19 pm
I run a quarter master twin plate.
I dont think you need a twin plate, the other supras at the drags i'm sure just run single plates with a beefy as pressure plate!
Postby avinesh » Wed Dec 24, 2008 12:16 am
Bazda wrote:I run a quarter master twin plate.
yea but the beefy pressure plate has been found to cause crank walk in supras.... :o
220.1 rwkw
jza80 supra = 11.7
avinesh
