Sweet! Awesome thanks Matt will keep that in minddeaf_rattle wrote:i have an engine stand you can borrow
I'm fairly anal about these sorts of things, so i like to think i have the right attitude to do it... biggest problem is what is the learning method? keen to take the time to learn and not rush things, would even be prepared to pay (being able to build and engine is sort of a bucket list thing for me)... i just don't know where to go if that makes sense?RomanV wrote:But if you want to do it, and you take the time to learn what you need to do, and you are methodical and make sure everything is clean, no reason why you cant.
RomanV wrote:I lol when people fit 'race' spec ACL bearings (or from who ever else)
When they have significantly worse tolerances than buying the factory bearings to suit the markings on the crank and block.
(Except in the case of when you get it linebored or whatever, and factory markings are no good...)
