l1ttle_d3vil wrote:NZ_AE86 - you can use either pulley, so long as you use the waterpump to match, so don't even need a rwd pulley or pump to run on a rwd setup. also pretty sure you can use the top outlets from other models too, ive seen a few different types which work.
BZG|Bling wrote:Parts might not come up too often too often due to hoardersHalf of which are probably toyspeeders
Users browsing this forum: No registered users and 26 guests
