1jz flywheel, where to get one
Postby Coldspark » Fri Jun 15, 2012 11:58 pm
whats my best bet?
1. go buy a cnc one off trademe
2. sec hand one
3. or get a new one though Toyota
chairs
Coldspark
Postby Mr Ree » Sat Jun 16, 2012 12:42 am
What does each option cost?
wak thud gush!
Mr Ree
Postby evil_si » Sat Jun 16, 2012 10:08 am
evil_si
Postby Coldspark » Sat Jun 16, 2012 10:06 pm
ill get some costs on Monday
is anyone on here using a cnc one? whats the quality like of them?
Coldspark
Postby MrOizo » Sat Jun 16, 2012 10:57 pm
Does it also matter what the clutch options are?
MrOizo
Toyspeed Legend
Postby Stott69 » Sat Jun 16, 2012 11:02 pm
How are you planning on balancing a cnc'ed one?
Stott69
Postby atmosports » Sun Jun 17, 2012 9:58 am
If the guy who made it, knew what he was doing a CNC machined flywheel would be pretty close to be being balanced anway. But if not or your anal, take it to you local engine/driveshaft/turbo etc balance(Depending on size of there machine etc) & get them to zero balance it. Else if it's like some of those Ford motors with either a piece removed or added to the flywheel to get the balance correct I've done that with a cnc mill before as well,probably a lot more accurately than the factory cast/forged etc flwyheels.
I make grinding hubs, that spin to 25,000+rpm slightly about 400-500mm dia by up to 200mm long, all turn & mill in CNC machinery then sent to Lynn Rogers for a final balance, balance is always very close as usually there might be one or two holes smaller than 3mm drilled to get the balance correct & these are balanced way more critically then you'd do a flywheel
atmosports
Postby strx7 » Sun Jun 17, 2012 8:10 pm
2nd hand on in my garage $200 inc courier and its yours.
Postby Coldspark » Mon Jun 18, 2012 7:29 pm
cost are
1. go buy a cnc one off trademe $459.00
2. sec hand one $200
3. or get a new one though Toyota $350
I would kinda like to get a lite weight one tho but whats is the stock flywheel weight?
Coldspark
