Manly Garage Vacuum Cleaner?
Postby ~SlideWays~ » Thu Nov 20, 2014 10:30 am
I need a vacuum cleaner that will handle metal dust, swarf, wood dust etc etc.
I've got an old bagless Electrolux and its pathetic, the filter lasts about 30sec and then it has no suction.
Are there garage orientated vacuum cleaners that will actually work?
~SlideWays~
Re: Manly Garage Vacuum Cleaner?
Postby 1I1 » Thu Nov 20, 2014 11:55 am
TRD Clicky >>Here
1I1
Postby MAC_HATER » Thu Nov 20, 2014 12:16 pm
^^ makes it fun
then you get yelled at because 15 minutes later you are just finding shit to blow about the place and making a mess worse than the one you just cleaned up D:
~SlideWays~: Cars + Males = Single, therefore: Poptarts?
MAC_HATER
Postby ~SlideWays~ » Thu Nov 20, 2014 12:26 pm
But that just makes metal dust clouds, or even worse rust clouds, which cover EVERYTHING!
~SlideWays~
Postby whynot » Thu Nov 20, 2014 12:29 pm
I spent 60 bucks at bunnings on a cheap shop vac. You just bang out the filter when it slows down and it's good as new again. The old man uses one as dust extraction on his diy sand blaster cabinet and I hooked one up to the orbital sander and sanded 2 cars. Both still working fine. I noticed the suction dropping off after about 15 min on the sander and you can imagine how well paint dust would block a filter.
whynot
Postby thegreatestben » Thu Nov 20, 2014 1:17 pm
I've got a stihl SE61 that I use alot for cleaning up renovation work so nails, gib dust, wood shavings, dirt, concrete etc.
Do recommend.
thegreatestben
Postby Bling » Thu Nov 20, 2014 1:26 pm
I have a "Supervac", which I think was from Repco for ~$99 on special. It works great, does wet and dry from memory. I've used to the vacuum the house before too, and the capacity means you don't have to empty it all that often.
Postby Townace » Thu Nov 20, 2014 7:31 pm
Cheap and cheerful wet/dry workshop vac from bunnings or similar works a treat.
I run an old speaker magnet in the bottom of mine to grab the metal filings and stop them doing any damgage should the filter rip or similar
Townace
Postby MrOizo » Fri Nov 21, 2014 12:56 am
The Vac you have will be fine once you make one of these.
Road Cone Dust Separator:
MrOizo
Toyspeed Legend
Postby ~SlideWays~ » Fri Nov 21, 2014 10:49 am
MrOizo wrote:The Vac you have will be fine once you make one of these.
This looks interesting!
Also the magnet is a good idea 8)
Failing that I'll look at getting a bunnings one.
Cheers guys.
~SlideWays~
Postby 85AW20v » Sun Nov 23, 2014 2:09 pm
Just need to factor in the waterblaster in the background and you'll have nice clean dust!!
See ya
Simon
85 MR2 20v
85AW20v
Postby Timmo » Mon Dec 01, 2014 8:14 pm
Lightweight baby
1991 MX5 Supercharged
Timmo
Users browsing this forum: Google [Bot] and 25 guests
