gauges
gauges
Postby 79rolla » Tue Sep 01, 2009 8:09 pm
hey, im looking at getting to get some gauges for the ke35
wanting to get 3 2" gauges to mount in the hole that was cut for a head unit at some stage..
the 2 i need is boost and oil pressure, and has been recommended that i get a water temp as well so i an keep an eye on it better..
getting my mates work to get some vdo ones in to have a look at
i want something that looks nice (pref black back ground) are accurate and reliable without being excessively expensive..
will prob be looking at around $400
what are your taught s on this? should i just get some autogauges instead? i quite like the black smocked gauges
the car is just going to be a street car, may see the track once or twice.. but nothing serious..
cheres, and sorry for the long post
past: AE82 FXGT
79rolla
Postby Adydas » Tue Sep 01, 2009 8:11 pm
DEFI!~!!!!!!!!!!!!!!!!!!!!!!!
mind you they cost, i have like 4 defis at a cost of around $1600...
Adydas
Postby 79rolla » Tue Sep 01, 2009 8:33 pm
yeah.. that's a bit too mutch for me ay.. not worth it for my current application..
past: AE82 FXGT
79rolla
Postby Dell'Orto » Tue Sep 01, 2009 8:51 pm
Defi wont suit the style of the car, I recommend either Smith's or VDO. $400 may not be enough for the VDO ones, unless you can get a hook up though...they dont come with senders which ramps up the price.
Postby Mr Revhead » Tue Sep 01, 2009 10:12 pm
yeah im with the VDO option. I though they weren't bad at all on price, but it was about 5 years ago....
its the oil pressure sender thats the $$ one isn't it? or maybe im thinking of the speedo....
Postby Dell'Orto » Tue Sep 01, 2009 10:19 pm
I think from memory the gauges are ~$100 retail, and senders are $30-40 each.
Postby 79rolla » Tue Sep 01, 2009 10:37 pm
yeah i got it all priced up including oil pres sender and a mechanical water temp and it was somewhere around the 400 mark (just rough estimate calculation)
those defi lookalike gauges look pritty cool.. but don't trust the quality enough. and i cant fork out for the real thing.. saame goes for some of thos autogage ones look cool, but dont know what sort of qulity they are, one of my mates swears by them, had a few sets without any problems.
past: AE82 FXGT
79rolla
Postby matt dunn » Tue Sep 01, 2009 10:42 pm
Do go for VDO, great and reliable and worth it,
But do not go mechanical,
mechanical gauges in general are a PITA,
to fit, to run the lead, to get the adapter to fit the engine,
just PITA in every way.
Can do hook up's on VDO at good prices, but I am away from work on holiday ( and out of the country) for the next 2 weeks from the end of this week so wont be able to untill after then.
Postby iOnic » Wed Sep 02, 2009 8:33 am
http://www.youtube.com/watch?v=QAU5Owidj54
Cost about $300 from memory
Postby Jazza » Wed Sep 02, 2009 9:30 am
79rolla wrote:yeah i got it all priced up including oil pres sender and a mechanical water temp and it was somewhere around the 400 mark (just rough estimate calculation)
Im running autogauges and theyre crap. My water temp says 120 (Thats max reading) when im actually at 85 degrees. Reads 80 at 65. My oil pressure gauge is also off. Just get good quality and stick with it
1996 Curren - On Tardme
Jazza
Postby Alex B » Wed Sep 02, 2009 9:47 am
Your 100% its not an install issue?
Postby tsoob » Wed Sep 02, 2009 10:07 am
Alex B wrote:Your 100% its not an install issue?
im running the boost one and it looks like its going past the 16psi mark my ecu is set to as well, but yeah check your install is 100% correct
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby matt dunn » Wed Sep 02, 2009 6:04 pm
Autogauge are shit
Autometer are the shit.
dont mix them up.
anyway,
boost $106
Oil Gauge $70
Temp Gauge $$72
Temp sender $18
Oil Sender $82
$348 all up,
and thats straight retail off the price on the shelf inc. GST.
Postby Dell'Orto » Wed Sep 02, 2009 7:10 pm
When I sold my MR2, I took out the Autometer boost gauge and put in an Autogage one, and gained 2psi...
Postby strx7 » Wed Sep 02, 2009 8:24 pm
Autoguage are actually pretty reasonable, they aren't a $200 a pop guage, but you dont expect them to be at the price of them. In all honesty, you are better off buying autoguage type guages and replacing them every 2 years than buying big ticket guages and expecting them to last 15 years.
a very respectable workshop that builds alot of racecars made the comment about autoguage guages "for the price, you cant go wrong"
Postby Guss » Wed Sep 02, 2009 8:31 pm
i've always taken the approach that the after a short time the numbers on the gauge are unimportant. what matters is where the gauge is in relation to where it normally sits.
Guss
Postby B1NZ » Wed Sep 02, 2009 8:42 pm
I had an autogage that told me my car was running 4PSI before I even installed it in the car :lol:
Subaru GF8 Wagon
Subaru GC8 rally car project
B1NZ
Postby strx7 » Wed Sep 02, 2009 9:13 pm
B1NZ wrote:I had an autogage that told me my car was running 4PSI before I even installed it in the car :lol:
thats cause it had been dropped before you got it. I have 2 booat guages that say i'm at 6 inches of mercury vacuum with the car off, same problem.
Postby matt dunn » Wed Sep 02, 2009 10:56 pm
Really,
all the people i know that run race cars would rather pay a bit extra an know that when the temp gauge says 80 the car is at 80, not somewhere between 90 and 130.
And replacing gauges every couple of years?
WTF? they are not even accurate when new,
they just fall apart as well in a few years.
VDO gauges in my car have been in there since I wired it for the previous owner over 15 years ago, and the temp gauge always reads with 2 degree's of the laptop display out of the link ecu.
Postby Jazza » Thu Sep 03, 2009 12:34 am
Positive its not an install issue, have had 2 different gauges in (diff brands) reading the same temperature as each other (Which is close to a heat gun reading) when the autogauge says its 85 degrees, meanwhile, i can touch my radiator coolant without burning my fingers
Jazza
