sergei wrote:Yes!, and while we do that we also should rally for authority-like excemption for trackday cars.
Correct me if I am wrong:
strx7 wrote:sergei wrote:Yes!, and while we do that we also should rally for authority-like excemption for trackday cars.
No you dont require an authority card, harness, seats a MNZ license etc etc to have a cage in your car.
You CAN have a rollcage in your car if it is CERTIFIED and the cage is to NZDRA/NZHRA spec - but their cages are for drag racing, not much thought of circuit racing physics has gone into to their type of cages.
If you have a car, that you wish to put a cage in, rather than just being an occasional track day thrasher, Join a MNZ club, LEARN about what other events are on that you can compete in, LEARN to drive you car even better, and become a better driver while having alot of fun, and meeting other like minded car/motorsport enthusiasts.
You will then learn why having a cage, seats, harness, MNZ authority card etc is THE RIGHT way to go. at the end of the day,
IF YOU CANT AFFORD ALL THE RIGHT SAFETY GEAR, YOU CANNOT AFFORD TO PLAY!!!
Shane - MNZ Scrutineer & Vice President of Motorsport Bay of Plenty.
sergei wrote:If cop stops you how they are going to measure the camber?
tsoob wrote:again this is why we need to do something about this.
Mark explained that if we get no head way with the people at LVV we may have to go to the minster of transport.
This will mean we need a lot of signatures etc.
strx7 wrote:Sergei find another car club, you are in auckland, there is over 10 MNZ car clubs in your area.
Which club did you used to belong to? there are certainly active clubs, and non active clubs, other clubs, like ours is VERY PRO ACTIVE. I think Pukekohe car club is probably the most active in your area as far as clubsport events go, and getting infomation out there
Dell'Orto wrote:tsoob wrote:again this is why we need to do something about this.
I'm sure we could organise a petition to get couriered around the main centres...get as many forums together and have a mass signing. 10,000 signatures would probably not be a major.
wde_bdy wrote:Skip the political rubbish and just deal straight with the LVVTA, no one else will care and will simply direct you to them anyway. The biggest problem you have is the retards that caused this problem like to call themselves "car enthusiasts" too and any public event you try to organise will just end up getting you bad press over what is really only a minor technical matter. As a whole the LVVTA process works and is a lot better than many other countries so be very careful trampling all over it. It was a very borderline thing 20 years ago to even be allowed to modify cars at all.
Callum
fangsport wrote:finally a logical response to the whole debacle. prior to LVVTA Certs, modified cars could get WOFs with a 'declaration' form. when these were phased out, NZ was close to going down the path of most other countries and allowing only cosmetic mods to normal road going cars (ie, not hot rods or motorsport vehicles).
fangsport wrote:finally a logical response to the whole debacle. prior to LVVTA Certs, modified cars could get WOFs with a 'declaration' form. when these were phased out, NZ was close to going down the path of most other countries and allowing only cosmetic mods to normal road going cars (ie, not hot rods or motorsport vehicles). NZ has the most relaxed modification rules in the world, and people still see fit to complain when they are tightened up.
2 simple ways of getting legal:
Modify within LVVTA guidelines and get it certed;
Modify within MSNZ guidelines and get an Authority card.
bitching and moaning because you want to modify your car to completely deminish any remaining steering/suspension geometry, is completely retatded, as is the modification.
am i crying that my TE71 will have to have Std struts re-fitted and 0 camber........... no, because next time it needs a WOF i will merely have to fill out a few extra columns in the MSNZ Authority form and pay the money .
true, to a certain degree. the most vocal ones, i suspect, are the "stance" freaks, that want 10degrees, not Joe bloggs that wants only a small increase over the maximum limit.Dell'Orto wrote:
People are moaning because its a ridiculous ruling...yes there needs to be some form of check, but half a degree is absurd. Why not set it at a blanket maximum of 2 degrees, thats plenty for a road car.
strx7 wrote:IF YOU CANT AFFORD ALL THE RIGHT SAFETY GEAR, YOU CANNOT AFFORD TO PLAY!!!
wde_bdy wrote:I disagree with the rules they have put in, but seriously for a road car 1 or 1.5 degrees should be plenty. If you have a multi-purpose car that isn't under an authority card it isn't hard to reset your camberplates at the track, probably at the same time you swap over your wheels.
Callum
sergei wrote:wde_bdy wrote:I disagree with the rules they have put in, but seriously for a road car 1 or 1.5 degrees should be plenty. If you have a multi-purpose car that isn't under an authority card it isn't hard to reset your camberplates at the track, probably at the same time you swap over your wheels.
Callum
The problem with that is when you increase camber, it also increases toe in, which is very difficult to adjust properly on the track. The "solution" is to have toe out on "normal" camber and when you set the camber on the track it brings toe where it supposed to be.
Users browsing this forum: No registered users and 35 guests
