What type of tyres do you have?
Postby tsoob » Mon Dec 12, 2011 6:23 pm
BZG|Bling wrote:
xsspeed wrote:I thought re002 were just a different tread pattern to re001.
Not sure, just what I got told. So I take it with a large bag of salt :lol: But yeah was pretty sure the RE002 won't be bad if the RE001 is sweet. So told em to flag the MY01s as I found out they are average as.
Going by the above comments the MY01 is a pretty shit tyre huh.... I just wanted tyres that handle the jandal especially in the wet. Sounds like the RE002 will do the trick. Tyres isn't something to cheap out on!
What is the useable life of a tyre Tsoob? The current tyres will be a couple/few years old now and have some cracking between the tread.
Who nerf'd the thread..?
All Tyres have a date stamped on them, and they do get pretty bad as they get older... the date stamp is 4 numbers on the side wall of the tyre the month and year of manufacture 0111 would be 1st month 2011 etc
Ideally you want the newest rubber you can get :)
Use able life is like how long is a piece of string..
Keeping them inside and garaged will make them last longer than in the rain and sun etc.
Rubber does perish and its just one of those things you need to replace sometimes
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby Luke - BZG » Mon Dec 12, 2011 7:30 pm
18" 245 and 265 german made Eagle F1 asymmetrics on work emotion cr kai's (a replacement set of rears waiting for the inevitable :twisted: )
235 and 255 RE001's on the stock 17" wheels, will be used for a couple track days then replaced with some form of slick/semi-slick.
Luke - BZG
Postby Bling » Mon Dec 12, 2011 7:36 pm
Cheers tsoob, will check my now two spare tyres later for dates. Might just trademe them as cbf storing them really.
Postby Looonie » Mon Dec 12, 2011 7:41 pm
Curious as to why my other post got edited.
For anyone interested, the part that somebody decided they had the right to delete (no freedom of speech on toyspeed I guess?) was:
+1 for buying from Nick @ Platinum Wheels, awesome service and great deals. Happily drive from Papakura to Glenfield to buy off him.
Rumple dee pumple dee doo...
Looonie
Postby eskimo » Mon Dec 12, 2011 7:51 pm
I'm running toyo proxie 4's 225 45 r17 on the front & 235 45 r17 on the back, Have had proxies 4's on the last 3 of my cars & cant fault them.
"If in doubt, flat out" Colin McRae 1968-2007
Current:2003 Legacy 3.0R Spec B
Previous: ST185 GT4, SW20 MR2, ST206 Curren, AE111 Corolla GT
eskimo
Postby Dell'Orto » Mon Dec 12, 2011 8:12 pm
I edited/deleted posts...we give you plenty of free reign Nick, no need to push it
Postby KinLoud » Mon Dec 12, 2011 8:19 pm
Car - 1998 AE111 4afe Corolla wagon.
I drive this car very hard - cornering, braking and accelerating (as much as a 4afe can)
Wheels - alloy 6.5x15
Current tyres:
Goodyear Eagle F1 Directional 5 (replaced the GS D3)
195/50/15
Grip - very good, dry or wet. Very impressed.
Response to steering input - good, but nowhere as good as the RE001.
Tends to move and squirm which took me a while to get used to.
Still experimenting with tyre pressures to see if I can improve this
Previous tyres:
Bridgestone Potenza RE001 Adrenalin
195/50/15
Grip - good
Response to steering input - very good, very direct, minimum squirm even when new with full tread depth.
Got 52,000kms before I replaced them with about 2 - 2.5mm ltread remaining.
Ken
Postby siren676 » Mon Dec 12, 2011 9:47 pm
Looonie wrote:+1 for buying from Nick @ Platinum Wheels, awesome service and great deals. Happily drive from Papakura to Glenfield to buy off him.
+2 Ive done the trek a few times from Drury, always excellent service
Anyway my car
EP91 N/a
Sees regular track work and is daily driven on the same tyres
Wheels - 15x6.5"
Currently running 195/50-15's front and rear
Front - Toyo Proxies 4's. Was running the same as the rear but a poor alignment wore them out
Rear - Sunfull(?) HF886's. Bought as it was all i could afford when i got my mags
Grips really well on the track when the tyres are at temp but when they aren't it gets a little tail happy when pushed hard.
Never tried anything more expensive so dont have anything to compare them to.
siren676
Postby B_giB » Tue Dec 13, 2011 7:58 am
235/45R17 GSD3 are no longer, I got the last two a few weeks ago hehe
Current: SXE10 Altezza
Previous:AE86 Trueno Notch Back: Gone but not forgotten :cry: :(
AE101 Levin 20V super strut
1994 Mercedes Benz C280 Sport
B_giB
Postby sergei » Tue Dec 13, 2011 8:44 am
Used GSD3 on my AE101, ST205 and ST165. As a road tyre it is very good (although subjectively Chinese made ones were crappier below 4mm).
Running RE001 on ST205 and iST, second set on ST205, awesome road tyre (rate it higher than GSD3), it wears out a bit quicker though than GSD3, but works till the end unlike GSD3.
Second set of RE001 is Australian made (first one was Japanese), and immediately noticed poor workmanship - Australians could not be stuffed trimming the casting excess on one of the tyre, and rest were trimmed but not as well as Japanese. Other than appearance the tyres are as good as Japanese RE001.
My next road tyre probably will be either RE002 or RE11.
On the track RE001 is a bit more predictable than GSD3, but it also not going to last beyond few laps (although it will give you plenty of warning). It took about 5 laps around Hampton Downs for GSD3 to turn into smocking jelly. They are completely unsuitable as track tyre.
If you going to use the car as primarily track day car, don't bother with road tyres, additionally some people call RE11 "semi-slicks", they are not semislicks, RE11S are, and they are very different tyre to RE11.
I am looking at R888 as track tyre, any other options? What about dunlop range?. I am looking for an affordable track day tyre, nothing too fancy....
Postby 1I1 » Tue Dec 13, 2011 8:55 am
Heard good things about Nitto NT01 semi-slicks. Similar price if not cheaper than R888 if I remember correctly
TRD Clicky >>Here
1I1
Postby Kiwi-Corolla » Tue Dec 13, 2011 9:02 am
tsoob wrote:All Tyres have a date stamped on them, and they do get pretty bad as they get older... the date stamp is 4 numbers on the side wall of the tyre the month and year of manufacture 0111 would be 1st month 2011 etc
Correct me if I'm wrong, but wouldn't 0111 mean the 1st week of 2011? All of the tyres I've ever owned have had a number like 3409, meaning it was made in the 34th week of 2009.
Kiwi-Corolla
Postby tsoob » Tue Dec 13, 2011 9:27 am
yes thats correct.. my bad typed it wrong, week/month is what you are looking for.
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby sergei » Tue Dec 13, 2011 10:20 am
1I1 wrote:Heard good things about Nitto NT01 semi-slicks. Similar price if not cheaper than R888 if I remember correctly
Only problem is the size availability: the NT01 don't come in many sizes.
Postby xsspeed » Tue Dec 13, 2011 10:26 am
Any one used yokohama Adrive r1's?
Postby Bling » Tue Dec 13, 2011 3:02 pm
Going by the above date marking theories, my rear tyres are from beginning of 2007 - not a bad effort 3-4mm left. Used to be my fronts. Fronts I just got are from about May this year, so that's good to know.
Postby saft » Tue Dec 13, 2011 3:15 pm
these are the tires on my car at the moment.. ..not a bad vintage.
good enough to run a mid-low 1:13 at hampton downs :lol:
saft
Postby nz_climber » Tue Dec 13, 2011 5:34 pm
Just got a set of RE002 on my wheels for the lotus 7, have yet to drive on them though, really wanted RE11 but none in stock and they are not going to be holding them anytime soon :(
Should last a few more laps on the track since the car will only be 600kgs. Didn't want a semi slick to start with while I learn my car (especially with the Manawatu weather!!)
On my daily I have supercats! and for a budget tyre they work pretty well, lot better than trinagles and other random brands etc!!
nz_climber
