Dell'Orto wrote:Also keep getting code 52, that's gonna be fun to fix...
Boosted_162 wrote:Got a pair of RE003's fitted to the front of the EP. Found my rear wheel bearings had a bit of play so tightened up. Hadn't checked since installing them so was expected.
Also found the right handbrake cable is gone, while the left is working alright. So will only replace the one which will save money!
GDII wrote:Boosted_162 wrote:Got a pair of RE003's fitted to the front of the EP. Found my rear wheel bearings had a bit of play so tightened up. Hadn't checked since installing them so was expected.
Last time someone replaced one cable on my MR2 (before I bought it) one cable was longer than the other so only one brake worked anyway.
