Neons, i kno its rice but.....
Postby SpeedRacer » Thu Oct 06, 2005 12:22 am
oh ok, figured it was basically something like that :?
Sinister Sleeper 35
SpeedRacer
Postby Alex B » Thu Oct 06, 2005 12:23 am
but its like an automatic switch, as i said youl find it on google id say :D
Postby Alex B » Thu Oct 06, 2005 12:26 am
http://home.howstuffworks.com/relay2.htm
There ya go.. unfortunatly how stuff works is full of adds now days :(
Postby AJz » Thu Oct 06, 2005 12:26 am
turns the neons on, lol
relay works as a middleman which switches the power to your device. Fogs lights etc use them. very common.
4 sides to a relay, again like pyro i cant remember the numbering
Positive 12V - Constant power, run from battery or other constant power source, can be run off ignition if you only want it on when the key is turned
Input - From the switch, also has 12V going in. Or in your case the door triger.
Ground - As it says, ground, ie chassis
Output - Again, as it says, output, goes to neons
I had vtax :(
AJz
Postby AJz » Thu Oct 06, 2005 12:28 am
bugger, bastards beat me to it, oh well........
8)
I had vtax :(
AJz
Postby mr pad » Thu Oct 06, 2005 9:30 am
Neons are ghey.
Why would you want to show off that you have a really cool green light that makes your feet glow?
But if your going to do it, do what perv said. Least that way they wouldn't be on all the time.
mr pad
Postby Kermit12a » Thu Oct 06, 2005 12:37 pm
Hook them up to the doors with a bypass swithch so if you want them on you can.
AE82 FXGT all the way
Go the Old School
Kermit12a
Postby snwtoy » Thu Oct 06, 2005 6:06 pm
Do something original.. use them to light your wheel arches or create a subtle glow in your bumper or something....
snwtoy
Postby SpeedRacer » Thu Oct 06, 2005 9:10 pm
yea thought bout that but they are unprotected so would prob short out if i stuck them outside in the rain :?
Sinister Sleeper 35
SpeedRacer
Postby slighty_sykotic » Tue Oct 11, 2005 12:08 am
I made a really cool picture and everything.....then i saw that there was a page 2, and that all questions had been answered...then i cried...then i decided to put cool picture up anyway. (for the stupid people, and cause my ms paint skills are clearly awesome.)
--Sykotic
slighty_sykotic
Postby Alex B » Tue Oct 11, 2005 12:11 am
Well my alarmon the AE95 beast uses neg trigger for when the doors open, so im pretty sure its right 8)
Postby mr pad » Tue Oct 11, 2005 9:55 am
$&#$% paint rocks. Only a real artieesst uses paint. Top marks etc.
mr pad
Postby SpeedRacer » Fri Dec 09, 2005 1:27 am
ok, i hav finally got roud to doin this :? and its all wired up and working :lol: 8)
However, when the key is off, it dosent work! which is pointless cos its not often u open ur door and the key is in the ignition already :? So where can I tap a continuous 12v+ from? that wont turn off after the key is off.
Don't relly want to have to run a line to the attery but will if I have to :cry:
Sinister Sleeper 35
SpeedRacer
Postby Alex B » Fri Dec 09, 2005 1:51 am
there is plenty in the car, just use a multimeter to find one, if you dont have one they like 20 bucks from DSE.
Postby Muzzie » Fri Dec 09, 2005 9:26 am
SpeedRacer wrote:ok, i hav finally got roud to doin this :? and its all wired up and working :lol: 8)
Anything that works when the car is off. Even tap into the stereos 12 volt memory if you needed. Or the hazard light switch, or the lights. Plenty of places to chose from.
Muzzie
Regular Poster
Postby barryogen » Fri Dec 09, 2005 10:13 am
pyro_sniper2002 wrote:http://home.howstuffworks.com/relay2.htm
use firefox with adblock extension.
barryogen
2ZZ Guru in training
Postby Vertigo » Fri Dec 09, 2005 10:14 am
have it running to the headlight switch, or the accessories switch on the ignition. or just solder them to the back of the ciggie lighter. i spliced mine into one ciggie lighter plug, and just fed the wire back into the dashboard, looks fine and works well.
TVIS just kicked in, yo!
Vertigo
Postby SpeedRacer » Fri Dec 09, 2005 11:32 am
wikid, got it working, had some wiring issues, not input voltage so it works properly now (ended up going on when door was closed not open)
Does anyone want a diagram of how this goes or are we all smarter than me?
P.S. barry, the sig is great, ppl don't get me eitha **looks at sykotic**
Sinister Sleeper 35
SpeedRacer
Postby barryogen » Fri Dec 09, 2005 1:31 pm
SpeedRacer wrote:Does anyone want a diagram of how this goes or are we all smarter than me?
I would like the wiring diagram... I have a few things I want to wire up like this.
I added that to the sig after some people thought I was serious, when I thought I was clearly being sarcastic.
barryogen
Postby CozmoNz » Fri Dec 09, 2005 2:50 pm
now "fuse box" can be replaced by anything, in this case, your door switch.
When door open (door switch on), power goes to switch, If switch = on, then power goes to relay (and indicator as seen here), when relay receives power it then allows a larger current through via 30 / 87, 87a can be used for foglights so that one foglight can run off different points of the relay (equal current maybe?, maybe when one blows the other wont go superbright? theyll both just always be superbright? lol)
anyhow, thats what i was told, oh and remember the fuse... nothing worse than burnt out wiring *shudder*
Rayne For President!
CozmoNz
