Masterton drags 26th/27th
Postby B1NZ » Sun Dec 04, 2005 11:11 am
What sort of revs were you launching at? From previous experience at MMP i found usually if you hold the revs at about 3000rpm then drop the clutch and play with the throttle a bit on take off you should get a good run, i was getting 2.1 60ft times consistanly and running in the high 14's to low 15's.
Also gear changes help alot too! In a 20v you should be changing just befor redline and you may be able to hold it in 3rd over the line depending on the launch which means 1 less gear change and a quicker time :wink:
Subaru GF8 Wagon
Subaru GC8 rally car project
B1NZ
Postby trueno_20v » Sun Dec 04, 2005 12:06 pm
I was launching at about 3500 any more than that and it would sit there spinning (sh*t tyres!!) yea i was just at the end of 3rd past the line
ADMIN EDIT: signature too large
trueno_20v
Postby NILPSI » Sun Dec 04, 2005 10:05 pm
I think by looking at your vid that like me u have an open diff! They are useless and semi slicks wont help you as you warm up one doing your burnout, then when you launch the other wheel will spin so your not really acheiving anything :(
All I do to try and get grip is run lower tyre pressures
17 Triton - The "free supplied by work" daily
09 Aurion Sportivo - The Daily
97 Trueno BZ-G - The Garage Queen
97 Supra SZ-R - The never ending project... now with added boost!!
NILPSI
Postby B1NZ » Sun Dec 04, 2005 11:08 pm
yeah, try about 20psi in the front tyres, and 40psi in the rears might help a tiny bit.
I found in my 20v sometimes i could make it across the line in 3rd depending on the launch
Subaru GF8 Wagon
B1NZ
Postby Loudtoy » Thu Dec 08, 2005 7:03 am
B1NZ wrote:yeah, try about 20psi in the front tyres, and 40psi in the rears might help a tiny bit.
I never could but then i always had higher traps than you unless it was side by side and your traps came up cos you used to get overexcited on launch, if i stayed in 3rd till i crossed the line i would be bouncing on the limiter for about the last 100 meters or so.
People used to ask me what rpm i was launching from when i raced, most people assumed i was launching off my rev limiter but realisticly was normally just over 3k on the launch control which is the easiest and cheapest way of dropping your 60 times if you can find an old gizzmo unit - the new ones don't work on toyota's :(
TS Member sine 2001
Prado To tow stuff with
Rodeo to do work stuff in
Loudtoy
Postby trueno_20v » Thu Dec 22, 2005 10:52 pm
Soo who will be comming to masterton on boxing day? Laughing
trueno_20v
Postby loose_unit » Thu Dec 22, 2005 11:25 pm
Not me, ive gotta work both days, it's a stupid time to have the drags, most retail stores open on boxing day.
Ill be at the last meet tho, cars getting a good tune done before that so will be hoping to get well into the 13's if the track is any good.
91 GT Starlet 5efte
231kw atw @ 18 psi
12.13 @ 185kph
loose_unit
Postby CAMB01 » Fri Dec 23, 2005 8:04 pm
I'll be there if the weather holds fine (fingers crossed)
Hoping to improve my times
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby trueno_20v » Fri Dec 23, 2005 9:29 pm
Sweet :D the weathers looking good i think!! :D
trueno_20v
Postby CAMB01 » Sat Dec 24, 2005 9:58 am
Sweet :D
My mates comin. Shes racing her trueno with blacktop 20v.
You two have to race should be interesting. Thats if your not afraid of being beaten by a chick lol. Think her best time is a 15.9.
CAMB01
Postby Pies » Sat Dec 24, 2005 4:26 pm
i should be over there :) wont be with th enew car this time tho.. maybe next year :twisted:
Current Rides:
Pies
Postby Loudtoy » Tue Dec 27, 2005 8:08 pm
So who went and who got new personal bests??
The meeting over this time is always one of the hardest to get new pb's at, less rubber cos less of the top v8's are there and generally as hot as anything as well.
So Spil People
TS Member sine 2001
Loudtoy
Postby trueno_20v » Tue Dec 27, 2005 9:31 pm
I got a 16 flat @ 88mph real sh*t tyres no traction trying to launch (2.7sec 60ft!!) not a bad trap speed though should be doing atlease mid 15's with good tyres and good launch?
trueno_20v
Postby CAMB01 » Tue Dec 27, 2005 9:44 pm
I managed to pull a 14.61 @ 93mph.
2.1 sec 60 foot.
I found the track to be really sticky, i was launching at 5000rpm, small amount of wheel spin and it bit hard.
Found it was just too hot to run any faster times.
CAMB01
Users browsing this forum: Google [Bot] and 28 guests
