heat treatments gt-r
Postby Lith » Fri Feb 24, 2006 1:11 pm
Ako wrote:The fact that its pointing at either the wall or the tree as it crosses that 60ft mark kinda puts a dampener on the fact it got there so fast :lol:
Have you seen any footage of the sub 8.5s runs?? They're pretty straight! I'd say the rest is more to do with hook up once its rolling without dropping off boost etc.
Lith
Postby Ako » Fri Feb 24, 2006 2:12 pm
barryogen wrote:anyone know what these guys HP/KW per ton is?
Limited to 850kgs, so assume about 900ish - even 1000hp is a midget for a 4wd. Rayglass is damn close to the 850kg limit I think, makes around 800hp, so call it approx 1000:1.
And DOC1LE is reckoned to be in the vicinity of 1300hp. 8O
Lith - haven't seen them, are they online?
Ako
Postby barryogen » Fri Feb 24, 2006 2:20 pm
heh, just wondered... was reading about a 400hp kit car that weighed ~550KG, thought it would be a fun car to drive :)
barryogen
2ZZ Guru in training
there this also
Postby ezy10s » Fri Feb 24, 2006 7:13 pm
DriftMonkey wrote:Yees true, but I never saw any official times from that car, and also I'm basing my view on using a stock block, not something completely rediculous like that funny car. Also the fact that it is over 4L kinda puts it out on contention for Sport Compact (I always thought the limit over here was 4L for and Import to be classed as an Import?)
Brad Personett ran a 6.49@217.12MPH-in pro rwd(sport compact in the states) in his toyota celica running a 2.7litre 3rzfe block(factory casting) back in the middle of last year.
Member #244
ezy10s
Re: there this also
Postby DriftMonkey » Fri Feb 24, 2006 7:46 pm
I'm guessing that's a 4 cylinder? If so then I guess that one takes the cake (the time looks a tad suspicious though, seeing as the current Sport Compact record is something like 6.40@220). Brent Rau is the only 4 cylinder tube frame car I've heard much about running that fast, so forgive me for being too lazy to put much effort into my search for the 4 cyl record :)
DriftMonkey
Postby ezy10s » Fri Feb 24, 2006 7:57 pm
http://www.nhrasportcompact.com/APCM/te ... &zoneid=11
check that.
pretty funny though doubting something just cause too lazy! man i thought i was a slacker
:wink:
Member #244
ezy10s
Postby Mr Revhead » Fri Feb 24, 2006 8:02 pm
6 sec is awesome for anything, but a 3rz?!?!?!? wtf do they do to it to get that much grunt 8O
heh
Postby ezy10s » Fri Feb 24, 2006 8:19 pm
hey youre the toyota expert! you tell me!
all i know is its on methanol and has a masiif turbo
Member #244
ezy10s
Postby Mr Revhead » Fri Feb 24, 2006 8:26 pm
:lol: well thats a start!
stick that in the work hiace and see how it goes!
Postby DriftMonkey » Fri Feb 24, 2006 8:31 pm
ezy10s wrote:http://www.nhrasportcompact.com/APCM/templates/news_template.asp?articleid=8923&zoneid=11
check that.
:wink:
Lol I wasn't doubting it cos I was too lazy to check up on it, I was just too lazy to have a proper look for the record in the first place :D I doubted it because it was 0.09 of a second away from the 6 cyl record, which to me seemed a little close, and also that article on says he went 6.61. Enough for the record (fair bit faster than the guy I was going on about :)) but not 6.49 as you quoted before.
DriftMonkey
oops
Postby ezy10s » Sat Feb 25, 2006 10:03 am
might help if i put the right link up!
http://www.nhrasportcompact.com/2005/ev ... al3results
bottom of page
Member #244
ezy10s
Postby Lith » Tue Feb 28, 2006 1:08 pm
Ako wrote:Lith - haven't seen them, are they online?
http://www.hsperformance.co.nz/VIDEOS/DOCILE.wmv
Thats the 8.35s pass :)
Lith
Users browsing this forum: Bing [Bot] and 27 guests
