barryogen wrote:wow, thats pretty hefty... I mean the first one you're almost always gonna need a cert(how many seats share exact anchorages with Toyotas?), although it would depend on what they consider to be part of the anchorages and what isn't, and the last one means that pretty much anything since 1997(probably earlier) needs a cert too.
Whats a cert cost these days?
TruenoBZG wrote:left the part out on the bottom which detailed that the only anchorages that CANNOT be changed, are the fixings for the rails themselves.
You could set up any rail system, so long as it is anchored on the original mounts for the old rails.
sigma wrote:Another hijack, is it alright to have to non reclining buckets in a 2 door car if you dont have rear seats and seatbelts anymore? does this need to be certed? has anyone here actually done it before? thanks!
Ash wrote:sigma wrote:Another hijack, is it alright to have to non reclining buckets in a 2 door car if you dont have rear seats and seatbelts anymore? does this need to be certed? has anyone here actually done it before? thanks!
The car needs to be recertified as a 2 seater car.
NZJester wrote:When I emailed the LTSA about this they said...info@landtransport.govt.nz wrote:I have been advised by our Vehicle Certification Unit (VCU) you can remove the seats if the removal is permanent. It is ok to remove any seat from a vehicle except the drivers seat and so long as the seatbelt for that seat is removed it won't affect the safety inspection (WOF) being issued.
Loudtoy wrote:you may find however that because you are altering the seat that is attached to the rains unless the seat is exactly the same dimensions externally as your old ones it will affect the way the belt anchorage works, as in the thing will be either pushed outward or pulled inward because the seat is thicker/thinner than your original meaning that if they wanted to be picky the could say no go for it, also unless the belt anchorage is on the actual rail itself (can't remember for bzgs) than you are altering the seat belt entirely and so will need to get a cert
HELBND wrote:i was referring to needing to be certified as a 2 seater
