Nope, THIS is the EVC.
Have a read heres a link to all old HKS controler PDF files in one handy place http://www.hksusa.com/faq/?ID=1647
Any way back to subject any electronic boost controler is vast improvment over any type of bleed valve.
GorGasm wrote:My profec b s2 cannot maintain an even boost level till redline as the amount of wastegate opening needed varies over the rpm range and the greddy profec controllers simply cant do that.
TRD_ZERO wrote:No No NO!!! Yoou definatly cant go past the hks evc series damn they were good there is a self learning mode the programs your boost curve into the controller and so on it was super easy to setup. I had a Evc2 or 3 i picked up 4 $145 and it was amazing serioously. Nothing Beats it. Nothing.
TRD_ZERO wrote:Weird i fitted mine a long time ago. Cant you just set the low boost settin at what you want it at so when it restarts it should be what you want. What version are you using? I dont remember haveing that problem. Do you have the manual? I downloaded it off the net somewhere.
Users browsing this forum: Majestic-12 [Bot] and 11 guests
