New Paint job? What did it cost you?
Postby Akane » Thu Sep 21, 2006 6:52 am
I was told red is one of the most "different" colour to make, something about a totally different pigment or something, and easy to fade, or something like that :/ Didn't know it costs more.
The paint itself ain't expensive, 500ml is approx $40, colour matched PPG.
If you really do decide to paint it yourself, prepare to spend 80% of the time preparing.
For my 2 sideskirts it was 2.5hrs sanding, 15mins masking, 3min primer, 1min for each coat x <insert number of coats>, and another 1.5hrs wet sanding, then 30mins - 1.5hrs of polishing, depending on how shiney you want it.
Give it to a pro if you don't want to DIY, but the quotes above is a good ballpark.
Postby matt dunn » Fri Sep 22, 2006 2:00 am
Akane wrote:I was told red is one of the most "different" colour to make,
Match, Red and White, a ther bare so many variations and they are so noticable when they are slightly out.
Postby RedMist » Fri Sep 22, 2006 8:17 am
I had tonnes of problems matching my primer colour.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby NZ_AE86 » Fri Sep 22, 2006 9:37 am
Mine cost $3800 including inside/cage/engine bay etc. It was a drop off/pick up affair too.
Current rides;
1985 AE86 Race/Rally Car
1986 Levin GT
NZ_AE86
